Members friquant Posted February 20 Members Report Posted February 20 (edited) Using the Consew C1000 servo motor with needle position sensor from this website: https://www.amazon.com/dp/B01N6IYMCZ Also running this 45mm motor pulley: https://www.amazon.com/dp/B06ZZ42TGY It is quite convenient that it can do single stitches (the majority of the time). The majority of the time it does give exactly one stitch, and it completes the stitch at its slowest possible speed, which with the gear reduction is about 110 stitches per minute. But about 10 percent of the time, when I tap the gas pedal to ask for a single stitch, it instead does the following: Goes one full revolution at HIGH speed, then Makes a big THUNK sound, then Goes one more full revolution at its minimum speed Anybody else having issues like this? Here's a video. In this video, you can see a wave in the belt when the thunk happens. (Perhaps the thunk is a brake??) Here is a video: Edited February 20 by friquant Clearer words Quote In search of the perfect hundred-dollar servo motor with needle positioner. friquant. Pronounced "FREE-kwuhnt"
kgg Posted February 20 Report Posted February 20 10 hours ago, friquant said: Using the Consew C1000 servo motor with needle position sensor from this website Are you using a speed reducer between the servo motor and the needle positioner? I would first replace the belt. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members friquant Posted February 20 Author Members Report Posted February 20 7 hours ago, kgg said: Are you using a speed reducer between the servo motor and the needle positioner? I would first replace the belt. kgg I have considered replacing the belt, but it still functions smoothly and it is old enough to no longer have a chemical smell, so I think I'll keep it for now. There is only one belt...from the 45mm motor pulley to the 80mm balance wheel pulley. (No other speed reducer.) Quote In search of the perfect hundred-dollar servo motor with needle positioner. friquant. Pronounced "FREE-kwuhnt"
AlZilla Posted February 21 Report Posted February 21 Assuming that the start position is the same every time you ask for a single stitch, it seems to me that the problem has to be a bad controller. If it starts in the same position every time and your foot tap is exactly that same every time, then it should do exactly the same thing every time. I wouldn't think the position sensor would have anything to do with the speed. Maybe a loose wire causing an inconsistent signal ... ? Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members friquant Posted February 24 Author Members Report Posted February 24 (edited) Amazon sent me a replacement, and both units exhibit the same behavior. Still troubleshooting. Edited February 24 by friquant Quote In search of the perfect hundred-dollar servo motor with needle positioner. friquant. Pronounced "FREE-kwuhnt"
