Members magilla Posted February 24, 2025 Members Report Posted February 24, 2025 I purchased an old Singer 111w110 sewing machine to sew some light leather projects. I was looking for a Juki or Consew, but this one came up on MarketPlace and was a good deal. The guy I bought it from didn't know anything about the machine, he buys what's left over from estate sales. This machine was mounted in an old desk, very poorly, but had a consew servo motor. He also had another Singer machine in a vintage sewing machine table. I got the 111w machine, servo motor and vintage table for $250, which I thought was a great deal. When I got the machine home, I started cleaning and oiling it to see if I could get it to sew. The table I got with it was for a smaller machine, so I had to cut a bigger hole to get the 111w to fit, but I haven't got the motor hooked up yet. So I am just turning it by the handwheel now and something seems like it is bound up, it turns with more effort than I think it should take. Also, the needle and middle walking foot kind of jump forward as I turn the handwheel. I wasn't sure if I could post videos here, so I put a short on Youtube below. If anyone has any ideas on what to check next it would be greatly appreciated. I did see some thread jammed under the hook mechanism and was able to lift if up and remove the thread, but that didn't seem to make any difference. The main belt has been replaced at some point with a neoprene belt, so it apparently has had some maintenance in the last 80 years. I have oiled everything that seems like it takes oil and tried playing with the foot pressure screw, both loose and tight. Also, the threads on the arm shaft that allow you to set the stitch length are partially broken/missing like most early 111w's. I tried playing with the settings on the stitch length adjuster and that didn't change anything as far as the binding. I also found that the 111w110 model is not very common, I couldn't find out much info on it, other that it appears to be a variation on the 111w101. The serial number dates it to prior to 1940, maybe 1938 or so. Quote
CowboyBob Posted February 25, 2025 Report Posted February 25, 2025 My guess is there's a spring missing in the stitch length,open the top oval plate,then push the needlebar front to back & see if you see movement there.There's a screw(#200607) w/a larger head on it maybe 1/4" & it is supposed to have a spring(#202295) under it. Singer 153W101-1 stitch length.pdf Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members magilla Posted February 26, 2025 Author Members Report Posted February 26, 2025 Bob, Excellent guess, right mechanism, two parts away. I took apart the feed driving eccentric mechanism and found one broken part, screw #200429. It had about 3/8" of the shaft broken off and missing in action, so the thread selector pin wouldn't engage. The spring you mentioned is there, but there is also a small bumper type part (#202301) that keeps the spring from chewing up the shaft that is also missing. I have ordered the missing parts and also found a replacement arm shaft that I will try to replace since the threads are messed up on the shaft. I will let you know when I get the parts installed. Thanks for your help! Matt Quote
CowboyBob Posted February 27, 2025 Report Posted February 27, 2025 (edited) On 2/26/2025 at 6:52 AM, magilla said: Bob, Excellent guess, right mechanism, two parts away. I took apart the feed driving eccentric mechanism and found one broken part, screw #200429. It had about 3/8" of the shaft broken off and missing in action, so the thread selector pin wouldn't engage. The spring you mentioned is there, but there is also a small bumper type part (#202301) that keeps the spring from chewing up the shaft that is also missing. I have ordered the missing parts and also found a replacement arm shaft that I will try to replace since the threads are messed up on the shaft. I will let you know when I get the parts installed. Thanks for your help! Matt You do what you want BUT it's going to be a job getting the old shaft out.You can adjust the stitch length by turning the screw with the point on the end. A lot of times people don't need to change the length much once they get it set up. Edited February 27, 2025 by Northmount moved answer from quote box Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
