Members GerryR Posted Tuesday at 03:04 PM Members Report Posted Tuesday at 03:04 PM I've had a little more time on my hands than usual and decided to mod a Chinese Patcher to handle M-style bobbins to get the added thread capacity. One of the goals was/is "no modifications to the existing machine" so I can get back to the original patcher just by swapping parts. Well, I got everything done "except" I need to either make a different swapable hand / cam wheel or make a different needle bar connection to get the additional needle down stroke, about 0.3". The cam for the bobbin rotation works as is, as the angles of motion are proportional. I don't know if in the end I will get it all working, but at least I can easily put it back to original. I think these patchers get a bad wrap, but mine has worked flawlessly. It's definitely a educational project. Comments and suggestions are welcomed. Quote
CFM chuck123wapati Posted Tuesday at 03:12 PM CFM Report Posted Tuesday at 03:12 PM I'm wishing you all the best and can't wait to see the outcome. I love mine too a little cleanup and a few tweaks and they run like a clock. Quote
Members GerryR Posted Saturday at 10:27 PM Author Members Report Posted Saturday at 10:27 PM Well, because I didn't have an easy way to make a new hand / cam wheel to get the added needle stroke that I needed, a machine mod was going to be needed. I had a second machine and chose to modify it to be sure the mods would work before messing with my good machine. To get the added needle stroke, I moved the pivot point of the arm by 0.75 inches toward the hand wheel. I had to machine the frame in order to relocate the pivot point, but it worked out pretty well. I have one small issue that I will address Monday and that will finish it. It is no longer a true "patcher" but after running it for awhile with different threads I will swap the parts over to my good machine which is motorized. Here's a few pictures of what I ended up with. Quote
