Members CBaker Posted April 14, 2025 Members Report Posted April 14, 2025 Hi - Hoping to get some advice on which machine to get. I have been hand sewing leather a few years but want to get a solid walking foot machine that can easily sew through no more than 1/2” veg tanned leather for bags, backpacks, etc. I have found two used industrial, cylinder arm Jukis - one is a LS-341N in great condition (looks almost new - NOT a 1341). The other is a DSC-245 (heavier use on it is visible). Both have been professionally serviced and come with a 90-day warranty from the seller on the machine head. From what I can find, the 341N seems like a slightly more heavy duty machine but wanted to see what you think. Is one easier to get replacement parts for? Maybe there is a clone that uses all the same parts out there? Would one be better for me than the other based on my use? I do not do saddles or tack but smaller personal things. Any concerns with one over the other? Thanks for your input. C Baker Quote
kgg Posted April 14, 2025 Report Posted April 14, 2025 11 minutes ago, CBaker said: Hi - Hoping to get some advice on which machine to get. Assuming the machines are in good operating condition. As a note the ls-341 is basically an older version of LS-1341. There is a topic that should answer your questions. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members CBaker Posted April 14, 2025 Author Members Report Posted April 14, 2025 Thanks for the link but it really doesn't address my questions about availability of parts, dependability, or which may be better suited and honestly, I have no idea was the last two points are even talking about. Since the LS-341N is older than 1341 then they are not the same but is the 341N still a solid choice? Any concerns about not being able to get parts for either option? In looking at the Juki manuals it seems the DSC-245 is a lighter duty machine - is that correct? The links reference to thread size says the 1341 can do more than the 245 but is that true of the 341N as well? Thanks. Quote
Members eblanche Posted April 14, 2025 Members Report Posted April 14, 2025 (edited) The DSC-245 uses a small size bobbin (I forget what size exactly) but the 341 uses style M larger size bobbin. You have to jump to the DSC-246 for M size bobbin. It seems most parts for the dsc series are readily available but have to order from Japan - 3-4 weeks. This is my experience for ordering a half dozen parts for a dsc-246. Yes, the DSC245 is more light duty than the 341. 21/69 thread for the 245 compared to 23/92 for the dsc-246. That's pretty light but I have never worked with leather. Engineers manuel for 341 versions: chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://semsi.com.mx/Manuales/JUKI/LS-341N,%20LS-341N-7%20Engineer%20Manual.pdf lists needle size as 14-24 for the non-auto version. Edited April 14, 2025 by eblanche Quote
Members CBaker Posted April 15, 2025 Author Members Report Posted April 15, 2025 Thank you! This was helpful. Quote
