Members JDFred Posted May 15, 2025 Author Members Report Posted May 15, 2025 (edited) 12 hours ago, pengkegu said: I just wanted to say that your work is incredibly beautiful and elegant. It’s clear that your skill level is very high—especially your leather carving, which is truly impressive. I’ve recently started learning how to make ring binders too, and from my experience, it’s best to make the inner leather about 2 cm shorter than the outer layer so that the fold looks neater. Also, it’s better not to use materials that are too stiff for the lining—leather fiber works best, otherwise it can look wrinkled. Thank you for the kind words. I only started carving leather about 8 months ago and building anything from leather about a year and a half ago. This was my first 3 ring binder so the learning curve was steep. The next one I’ll have to try making my liner shorter and only glue the edges instead of glueing the entire liner to the cover. That may also help with the keeping it closed trouble I had. Thanks for the advice. Edited May 15, 2025 by JDFred Quote
Members Sheilajeanne Posted May 15, 2025 Members Report Posted May 15, 2025 (edited) That is some awesome work! I'm sure your friend is very pleased with it! Back in my teens, I had a summer job making binders in a factory, and knowing exactly how a binder is put together, I am curious as to how you converted a plastic binder to leather. A binder is made of 3 layers - an outer plastic layer, an inner cardboard layer of 3 pieces - one for the spine and two for the covers, then an inner layer of plastic. The rings are attached with 2 rivets that go through all 3 layers. So, I'm curious to know how you were able to remove the rivets? Or did you leave them and the outer layer of plastic in place and just cover them with leather? What size is the binder - does it take 8 1/2 x 11 paper? Asking because I've often thought of doing something similar! It's also possible to buy the rings separately, but of course, that would be more expensive than repurposing them from a plastic binder, which was likely just lying around the house! Edit: I think I know why the leather of the inner liner bunched up. The same thing happens with the inner liner of a wallet when you fold it. To prevent it, the inner liner has to be slightly smaller than the outside of your piece. I'm unsure of exactly how much, but if you fold the piece in half before doing your final cutting and stitching, you will likely be able to see how much you need to cut away for a good fit. Edited May 15, 2025 by Sheilajeanne Quote
Members JDFred Posted May 16, 2025 Author Members Report Posted May 16, 2025 8 hours ago, Sheilajeanne said: That is some awesome work! I'm sure your friend is very pleased with it! Back in my teens, I had a summer job making binders in a factory, and knowing exactly how a binder is put together, I am curious as to how you converted a plastic binder to leather. A binder is made of 3 layers - an outer plastic layer, an inner cardboard layer of 3 pieces - one for the spine and two for the covers, then an inner layer of plastic. The rings are attached with 2 rivets that go through all 3 layers. So, I'm curious to know how you were able to remove the rivets? Or did you leave them and the outer layer of plastic in place and just cover them with leather? What size is the binder - does it take 8 1/2 x 11 paper? Asking because I've often thought of doing something similar! It's also possible to buy the rings separately, but of course, that would be more expensive than repurposing them from a plastic binder, which was likely just lying around the house! Edit: I think I know why the leather of the inner liner bunched up. The same thing happens with the inner liner of a wallet when you fold it. To prevent it, the inner liner has to be slightly smaller than the outside of your piece. I'm unsure of exactly how much, but if you fold the piece in half before doing your final cutting and stitching, you will likely be able to see how much you need to cut away for a good fit. Thank you, he was pretty excited when I sent him the pictures. As to the construction I used side cutters to remove the rivets on the binder rings that attached them to the cover. There were tubes that the rivets went through that I used a Dremel to trim them flat to the bottom of the binder assembly. Then I put it together like you described, but with leather and plastic instead of plastic and cardboard. The cover on the donor binder was a heavier single sheet of plastic so I cut it into 3 pieces a front, back, and spine. I trimmed the edges of the plastic to be about a quarter inch from the edge of the leather, and left a half inch gap between each cover piece and the spine so it would fold easier. Then I glued them to the leather cover with contact cement and then glued the liner to that. That is part of the wrinkle problem was the same size liner as the cover and glueing the liner completely to the cover. I used #9 copper rivets to attach the rings to the cover. After I folded it, which was challenging I covered it with a towel and left my smaller piece of marble on it overnight then did the same thing to the other side the next day and mostly won the battle the keep it closed. Yes it is 8 1/2 x 11 paper sized. I figured you could get rings by themselves but I’m not sure where. Forgive my run on style of writing I hope this answered your questions and helped. Quote
Members Sheilajeanne Posted May 16, 2025 Members Report Posted May 16, 2025 It is possible to get the spines separate from the binders, but you have to buy more than one: https://www.amazon.ca/GORGECRAFT-Mechanism-Replacement-Notebook-Organization/dp/B0D9Y52Q42/ref=sr_1_19?dib=eyJ2IjoiMSJ9.8NrSbrqYITZvlCynqNpfPu-exYO4tl-IF9ia6PXcoSTyTXvV9nWv0Xg7qkbIn10tvLbazE6xn9rSz4gOWUj9uicoIo2jF7m3urxkAgkzQeartloL-wr6CyUEXhiVsETdikB4Jo2w1ROuR7SDmiIapV9R0fAZAqORWOWArg80HKt5ss7_WrAXfUKW39pJqJSUxhEw-5m3O2jY7dN3kHUOYJAUfGhnMf8Y0stERUwBkXdTyVEhiwIr1yN-5AkwEMEPElTQHUcHt9RJJ9cdv1PUsoniPYwqr992Kcw5u_LlTd4.38BT56S29bq3XSbAMNincPJPxD0uWs3bIAd9EIpxxV4&dib_tag=se&hvadid=605132128236&hvdev=c&hvlocphy=9221298&hvnetw=g&hvqmt=e&hvrand=2623142170463263152&hvtargid=kwd-324338471741&hydadcr=19050_13435280&keywords=3%2Bring%2Bbinder%2Bspine&mcid=a6b31fa6d8d2328ebe33b33d7487becb&qid=1747362180&sr=8-19&th=1 Given how many different sizes there are, I'd double check that I picked the right one before placing an order! The British sized paper is different from North American sizes! Somewhere I have a leather notebook holder which holds an 8 1/2 by 11 pad. I'll see if I can find it so I can tell you how the inner liner is attached. I'm pretty sure it's not glued, and like I said, the inner liner has to be slightly smaller to allow the holder or binder to fold without wrinkles. I know for sure the plastic ones aren't glued. When they fall apart from age, the cardboard stiffener isn't attached to the plastic. Quote
Members JDFred Posted May 16, 2025 Author Members Report Posted May 16, 2025 1 hour ago, Sheilajeanne said: It is possible to get the spines separate from the binders, but you have to buy more than one: https://www.amazon.ca/GORGECRAFT-Mechanism-Replacement-Notebook-Organization/dp/B0D9Y52Q42/ref=sr_1_19?dib=eyJ2IjoiMSJ9.8NrSbrqYITZvlCynqNpfPu-exYO4tl-IF9ia6PXcoSTyTXvV9nWv0Xg7qkbIn10tvLbazE6xn9rSz4gOWUj9uicoIo2jF7m3urxkAgkzQeartloL-wr6CyUEXhiVsETdikB4Jo2w1ROuR7SDmiIapV9R0fAZAqORWOWArg80HKt5ss7_WrAXfUKW39pJqJSUxhEw-5m3O2jY7dN3kHUOYJAUfGhnMf8Y0stERUwBkXdTyVEhiwIr1yN-5AkwEMEPElTQHUcHt9RJJ9cdv1PUsoniPYwqr992Kcw5u_LlTd4.38BT56S29bq3XSbAMNincPJPxD0uWs3bIAd9EIpxxV4&dib_tag=se&hvadid=605132128236&hvdev=c&hvlocphy=9221298&hvnetw=g&hvqmt=e&hvrand=2623142170463263152&hvtargid=kwd-324338471741&hydadcr=19050_13435280&keywords=3%2Bring%2Bbinder%2Bspine&mcid=a6b31fa6d8d2328ebe33b33d7487becb&qid=1747362180&sr=8-19&th=1 Given how many different sizes there are, I'd double check that I picked the right one before placing an order! The British sized paper is different from North American sizes! Somewhere I have a leather notebook holder which holds an 8 1/2 by 11 pad. I'll see if I can find it so I can tell you how the inner liner is attached. I'm pretty sure it's not glued, and like I said, the inner liner has to be slightly smaller to allow the holder or binder to fold without wrinkles. I know for sure the plastic ones aren't glued. When they fall apart from age, the cardboard stiffener isn't attached to the plastic. Thanks for the link. I glued the whole thing because I over build everything and I don’t know any better. On my next liner I’ll try making the liner smaller and only glue the edges and see if that turns out better. Quote
Members Sheilajeanne Posted May 16, 2025 Members Report Posted May 16, 2025 Right, should have said only the edges are glued! Gotta have something holding it together! Quote
