esantoro Posted March 11, 2007 Report Posted March 11, 2007 I watched the Stasiak video on sharpening, and now want to make one of those boards with sandpaper, leather lace with rouge, and strip of leather with rouge for polishing. Have any of you ever made one of these and made modifications? I wnt out to a $.99 store and bought a hardboard clip board and took off the metal parts. These are the steps to follow from my understanding: 1. glue down to one side of the hardboard a 2" wide strip of 600 grit wet/dry emory paper. 2. to the other side, glue down a 2" wide strip of leather, flesh side up, to be impregnated with rouge. From the video, it seems that chamois leather is used. I don't have any. I have veg tanned and chrome tanned. Should I get some chamois leather, or just use the fleshiest leather I have on hand, which at this time is probably 8 oz. veg tanned? What about 4 oz. suede? 3. Cut two strips of veg tanned lace and glue them in the space between the emory paper and the stropping leather. I understand I should use 8 oz veg tannned lace for this, one rounded one not. But how should I glue down the laces? Should the grain side of the lace be glued down and the flesh side up, or should the lace be glued down on its side? Thanks, ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Contributing Member Regis Posted March 11, 2007 Contributing Member Report Posted March 11, 2007 I don't know about the lace but, the 2" wide strip of leather is grain side up. There have been a few discussions in this forum about sharpening and a lot of folks use a business card or folder stock impregnated with rouge. I've tried that and it has improved my sharpening. It seems that with a softer surface, you round the edge when stropping. So if you use leather, use a light weight rather than that 8oz. I watched the same video and am curious about the lace also. Best of luck, as I am finally getting a "sharp" edge for the 1st time ever. Regis Quote God, Family, and Country (although liberals are attempting to destroy these in the USA)
Members whinewine Posted March 12, 2007 Members Report Posted March 12, 2007 Also, glue the sandpaper down with rubber cement, rather than contact cement, so it can be removed & replaced when it is worn out. Quote
esantoro Posted March 12, 2007 Author Report Posted March 12, 2007 (edited) Also, glue the sandpaper down with rubber cement, rather than contact cement, so it can be removed & replaced when it is worn out. Great idea. The same with the stropping leather? Would 2 to 5 oz chrome tan be good for the stropping cloth, or should chrome tanned not be used at all? What leather should be used? Thanks, ed Edited March 12, 2007 by esantoro Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
esantoro Posted March 12, 2007 Author Report Posted March 12, 2007 Great idea. The same with the stropping leather? Would 2 to 5 oz chrome tan be good for the stropping cloth, or should chrome tanned not be used at all? What leather should be used?Thanks, ed What do you allthink about putting down a strip of 220 grit emory paper as well as 600? Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Members Brandon Posted March 12, 2007 Members Report Posted March 12, 2007 What do you allthink about putting down a strip of 220 grit emory paper as well as 600?Ed Maybe you could ask Andy directly at denver@leatherfactory.com Quote
Dale Posted March 12, 2007 Report Posted March 12, 2007 Andy's a great knowledge resource, but I think he over-complicated this one. I haven't seen the video, but I no longer cement down the wet/dry and 600 grit is pretty coarse to deal with. I don't cement the sandpaper down because I would spend more time changing it than actually using it. Truth be told, I don't routinely spend any time with the paper. The strop is used the majority of the time. Only when a blade is in bad shape is it necessary to use the paper. The grit used at that point depends on how bad the blade is. If the blade is rusted and pitted I would start at around 220 grit (after using the bench grinder as necessary). Move up a step to the 400 range, move up again several more times until I'm in the 1500 - 2000 range, and then maintain it with stropping. If it gets to the point where stropping doesn't help anymore, I'd probably start with the paper using the 1000 - 1500 grit. As always, your experience and mileage may vary. Bruce Johnson or Romey (I think he's writing the tutorial?) may have a better opinion. Dale Quote Dale Hietala www.moonlightartstudio.com
Members whinewine Posted March 12, 2007 Members Report Posted March 12, 2007 Great idea. The same with the stropping leather? Would 2 to 5 oz chrome tan be good for the stropping cloth, or should chrome tanned not be used at all? What leather should be used?Thanks, ed I would not use chrome at all, as you need something to absorb the rouge/oil (some people use a light base of oil & apply the rouge heavily over top of that; others just rub the rouge over the leather, but ultimately the pores on the leather need to be open to take in the rouge & I don't think the structure of chrome is quite the same). Quote
Moderator bruce johnson Posted March 15, 2007 Moderator Report Posted March 15, 2007 Regarding the emery paper. I go it through it so much, and so many grits, I would spend half my time gluing a new piece to the board. I tape a full sheet down to a chunk of marble with masking tape. Gives me a nice wide flat surface. The marble weighs enough it ain't going anywhere, safety factor. I used to only go to 800 and then to the strop - an 8X24" strop, with 3/4 commercial oak leather - the firm stuff, Barged to hardwood, grain side up. Now I go to finer paper before going to the strop. Once you find the kind of stroke you can make on a big strop, you won't go back to a small one. More time on the strop and less time in the air going back to start like on a short stoke strop. As far as glueing down a piece of lace or thin leather to sharpen tools with round edges. If my tool is ground on a radius, I want to keep THAT radius. I find something firm with that radius like a dowel, smooth nail, screwdriver blade, whatever, and wrap the wet/dry around it to hone with. Then strop with crocus wrapped around it. I think that sharpening tools is probably one of the bigger evolutions we go through with leatherwork as we progress. Bruce Johnson Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
esantoro Posted March 15, 2007 Author Report Posted March 15, 2007 Regarding the emery paper. I go it through it so much, and so many grits, I would spend half my time gluing a new piece to the board. I tape a full sheet down to a chunk of marble with masking tape. Gives me a nice wide flat surface. The marble weighs enough it ain't going anywhere, safety factor. I used to only go to 800 and then to the strop - an 8X24" strop, with 3/4 commercial oak leather - the firm stuff, Barged to hardwood, grain side up. Now I go to finer paper before going to the strop. Once you find the kind of stroke you can make on a big strop, you won't go back to a small one. More time on the strop and less time in the air going back to start like on a short stoke strop. As far as glueing down a piece of lace or thin leather to sharpen tools with round edges. If my tool is ground on a radius, I want to keep THAT radius. I find something firm with that radius like a dowel, smooth nail, screwdriver blade, whatever, and wrap the wet/dry around it to hone with. Then strop with crocus wrapped around it. I think that sharpening tools is probably one of the bigger evolutions we go through with leatherwork as we progress. Bruce Johnson This forum is absolutely fabulous. I was also thinking that it would seem better to have larger surfaces for stropping and sanding. I don't have the space to devote a marble slab to anything but puching, skiving, and the like, but I think I will devote one legal size hardboard for sanding, one for stropping. I've got some commercial veg tanned. It's supposed to be 4/5 ox but is more like 3/4. I'll use that, per Bruce's recommendation. would Neatsfoot oil be suitable as an agent to hold the roughe to the leather? Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
