Hi everyone,
I'm trying to create a new post, but I keep running into an issue when I try to upload photos. Every time I select an image, it just shows "upload failed" and I'm seeing an error code -200.
Has anyone else experienced this, or does anyone know what might be causing it? Any suggestions on how to fix this would be greatly appreciated!
Thanks in advance for your help.
Get  a simple program . . . put it on your computer
Adobe photo shop elements 2.0 is a really good one . . . it's 5 bucks on Ebay . . . comes with a disc . . . don't buy one that is a down load as you will forever be plagued with ads and adware
Use it to size the photos to 800 by 600 pixels . . . and an overall size of 500 kb or so.
Then use the choose files below . . . go to your file on your computer . . . choose the pic . . . and it'll load.
You can do a lot with that little photoshop program afterwards as well.
May God bless,
Dwight
www.dwightsgunleather.com
Thanks a ton! You’re too kind.
