Im wondering if my problem is a safety clutch as since having a minor sewing problem(though there were about 4 rotations worth of thread caught up under the bobbin holder) the hook & needle timing appears to be waaaay out now, about half a rotation away from meeting . I've never heard of a safety clutch. Does anyone know whether an old 291 would have one?
4 hours ago, susiesmooth said:
I'm wondering if my problem is a safety clutch as since having a minor sewing problem(though there were about 4 rotations worth of thread caught up under the bobbin holder) the hook & needle timing appears to be waaaay out now, about half a rotation away from meeting . I've never heard of a safety clutch. Does anyone know whether an old 291 would have one?
I've split your post off the old thread you tagged onto.  Much better to start a new thread and specific to your machine.
  • 3 weeks later...
Thank-you!
  • 1 month later...
Did you get your machine running?
I'm not familiar with the 291. If a machine has a safety clutch, it will likely be built into the timing cog underneath the machine. Follow the timing belt from the main shaft down to the horizontal timing shaft. The cog on the horizontal timing shaft---if it has levers and pawls on the right side of it, your machine has a safety clutch.
Here's a video by Uwe that shows safety clutches:
https://www.youtube.com/watch?v=N-MClgDKnq4
friquant. Like a frequent, piquant flyer.
Check out my blog: Choosing a Motor for your Industrial Sewing Machine
