i built myself a set, but i didn't use a pattern i just looked at some pictures, then drew a real-sized profile pattern. i cut out two and pinned them to my stirrups to make sure that i could get my foot in all the way. then i laid them out on the table and put the tips (where your toe would be) together, and i placed the heel part (the part that will be attached to your stirrup bolt) the same distance apart as the meacurement of the stirrup. in otherwords, if your stirrup measure 4 1/2 across at the bolt, then thats how far apart the heel of the pattern needs to be.
be sure to lay the patterns down on another piece of paper, so that when you get them set up, you can trace out the top piece. some people have their taps built in three pieces like thise. i used these steps and taped all three pieces together, then cut out my leather in one piece, and it worked well
I hope that all wasn't too confusing... :scratchhead:
It seems to me that Shop Talk magazine did a thing on taps a couple of months ago, and there were patterns for a few different styles. I won't be going back down to the shop until next week, but I'll check and see if I can find the issue.
Mike
My choice early in life was either to be a piano-player in a whorehouse or a politician. And to tell the truth, there's hardly any difference.
Harry S. Truman
