Hello! I've been a reader here for years and seeing other people's machine problems and the comments from other forum members suggesting fixes has helped me many a time. This week I've experienced a machine problem of my own, and for the first time I can't find anybody who's had the same issue, so I'm posting this with hopes that someone wiser than myself might be able to help me out. I've been sewing for nigh on 45 years now, but I'm still no machinery expert. I can figure out most little things (tension—it's always the tension!) but this one has me stumped.
I've got a nice little Juki 5550N that I bought new (back when I could afford to buy things new!) I've had it about 9 or 10 years now I think, always sewing the same sort of stuff, but recently it's been acting up. I've noticed the occasional skipped stitch, and have noticed the thread momentarily going slack now and then. The past few days I've been tearing my hair out trying to diagnose the problem (and I lost my hair years ago, so that take some effort!) I'll list what I have tried at the end of this post, but right now I'll tell you what I've figured out. I think this issue is in the bobbin area, with possibly the thread catching on something or having trouble making it around the shuttle. It still sews and produces nice stitches most of the time, but there is definitely an issue. When I did a test sew just using the handwheel, I noticed that resistance is felt when the take-up lever is reaching its lowest position and just starting to move back upwards. If I continue to move the handwheel, two little pops are heard, as if the thread is catching somewhere and being released. As I mentioned earlier, when sewing with this issue, I've started to see the occasional skipped stitch, sometimes two in a row, and occasionally the thread will momentarily go slack between the take-up lever and the needle, justjsut for a moment. Then it gets tension again. I've made some videos showing the behaviour while handwheeling. I'll link those at the end of this post.
Here's what I have tried: I've changed the needle for a new one. I've changed the size of the needle (even though I've been sewing with that size and that type of thread for years with no problem.) I've tried different cones of thread. I've changed the bobbin. I've tried a different bobbin case. I made certain the needle was inserted correctly. I've rethreaded the machine. I've disassembled the upper tension assembly to make sure it wasn't clogged with lint, and carefully reassembled it. I've adjusted the tension to make sure it is correct, and it does form nicely balanced stitches. I've taken off the needle plate and feed dogs and cleaned the bobbin area. I've oiled the machine. I've checked to make sure there are no foreign objects clogging the bobbin area (and there are none I can see.) That's about the extent of my machine knowledge, and now I'm stymied and frustrated.
On to the videos! I tried to shoot from a few different angles to give y'all the best views possible. I'm handwheeling slowly so you can hear the pops hopefully. They're happening just as the take-up lever reaches the bottom and starts back up, and I've tried to show both the bobbin area and the take-up area so you can see how they correspond, and have also done a closeup of the bobbin area.
Test sewing on scrap fabric: https://youtube.com/shorts/CofAeMaxJ8A?feature=share
Needle plate removed, shot from left: https://youtube.com/shorts/794Q-e1iLlw?feature=share
Needle plate removed, shot from right: https://youtube.com/shorts/pplD9J6i8Zo?feature=share
Needle plate removed, closeup from front: https://youtu.be/9bncMsKGbBE
Any suggestions would be SO appreciated. I'm at my wit's end and haven't gotten anything done for a week or more. Between that and the floods, it hasn't been the best of times here in NC! Thanks so much.
  • Replies 22
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Wow it's hard to see down in there. I'm used to having a vertical-shafted hook where you can see the thread take a round trip.
Can you take one more video with the feed dogs removed, as close as you can but still in focus, and move the handwheel very slowly. (About four seconds to do a full turn ought to do it.) Then maybe we can see what's clunking around.
If we can't see it from above, you may be able to get a shot from below the left side. (This may require partially disconnecting the arm that the feed dogs ride on so we can get a better view)
If using an iPhone, Uwe made a demonstration of how to lock the focus on an iPhone for taking close-up videos:
https://www.youtube.com/watch?v=twl_V_vlq2Q
friquant. Like a frequent, piquant flyer.
Check out my blog: Choosing a Motor for your Industrial Sewing Machine
I shall do this first thing tomorrow! Thank you so much for the suggestion friquant!
@thobgood
When a machine that normally sews well suddenly starts missing stitches, there are three usual suspects. The first is when the needle and hook are out of time. The second is when the check spring motion is incorrect. The third is when the foot pressure is too light to hold the material flat during the needle take-up cycle.
Since you have removed the cover plate, you can easily see if the hook is intersecting the needle above the eye, but still within the cutout "scarf." Where the point of the hook is can matter a lot, depending on the quality of the loop that's formed by the ascending needle. You could have perfect timing, but a too small thread loop that might not persist when the hook arrives to pick it off. I normally time my machines so that the hook intersects the needle 1/8 inch above the eye after it ascends about 1/8th inch. This isn't set in stone, but is a good starting point. If your timing isn't close to that, either move the needle bar or the hook.
The quality of the loop is determined by two main parts. The first is the motion of the needle. The needle needs to go all the way down with the thread basically taut, then begin to ascend after the thread loosens up. That's where the upward motion comes into play. The hook must wait until the needle comes up as mentioned before. But, if the needle rises as specified and the hook arrives at the designated position and the loop doesn't get picked off reliably, the usual suspect is the check spring assembly!
The check spring assembly usually has these three adjustable components.
  1. The stop motion bracket. This is a movable bracket that stops the downward motion of the spring where the thread comes out of it. It must keep tension on the top thread until the needle pierces the top of the material. Then it can stop moving. You might let the spring move down after the needle penetrates the bottom layer if it leads to better results. But, never stop before the needle meets the top or it might separate the thread and shred it!
  2. The slack adjustment. This is usually a curved slot with a tiny screw that is set to give a decent amount of slack thread. Normally, setting it to the far left gives the least slack thread and vice-versa. The normal position is dead center in the slot. A tighter setting leads to tighter laying stitches and the opposite direction leads to looser stitches.
  3. The spring tension adjustment. The tension is adjusted by finding and loosening a screw that is close to the body. It locks the shaft holding the spring in its position. That shaft is slotted on the outside for a flat blade screwdriver. Loosen it and use a screw driver to rotate it one way or the other until it just has enough pressure to hold the thread taut until it stops moving down. If it is too light, the spring may not move all the way down, which can lead to skipped stitches. However, it is it too tight, it may override the main thread tension disks setting. Balance the overall thread knot position by adjusting the top disks after any adjustments to the check spring assembly, and/or the bobbin spring.
This may be a lot to absorb, but, it's important to understand. By playing with these adjustments you will better understand why your machine sews as it does, or misses stitches.
The last thing I mentioned was the foot pressure. This is actually a two pronged issue. The foot, or feet in a walking foot system, must hold the materiel flat as the needle ascends and the hook arrives at pick-off time. If the material lifts with the needle, you will probably get skipped stitches! So, tighten the foot pressure screw on top of the head! But, what if you have tightened the foot action and the material still lifts between the legs? Yep, skipped stitches! When this happens, buy another foot with less space between the inside of the legs!
Recap. Either confirm or adjust the nook to needle timing. Adjust the quality of the thread loop via the check spring. Make sure your presser foot is able to hold down the material between the legs. Once you fine-tune these settings, your stitches will be more reliable. Afterward, you might want to tweak the hook position for the quietest pick-off. If it is too close to or too far from the needle's eye, the thread will snap as it goes around the hook. It is usually louder if the timing is a little late. Try advancing the hook a little. Just make sure it arrives about 1/8th above the eye after the needle rises about 1/8th inch. Your manual may give the exact factory specification for timing the needle. If so, use them. The check spring slack setting can fine tune the quality of the loop.
I hope this helps!
Posted IMHO, by Wiz
A lot to absorb indeed, Wizcrafts, but exactly the sort of information I need! I shall make the video that friquant requested earlier, and then I shall delve into all the information you have provided me.
I always see you answering people's questions in here over the years, and that's very kind and generous of you. I appreciate your wisdom and your assistance. Crossing my fingers I'll be smart enough to figure out a solution with the information you've given me. Thank you so much!
That whole post should be a sticky entitled "When Your Sewing Machine Skips Stitches". I'm going to print it out and go through all my overlooked check springs the next time I have to work on my machines.
Thanks for the time and effort putting that together.
- Voltaire
- Aristotle
Okay, I have made some more videos as requested by friquant. (I've actually made a few more videos, some while the machine is threaded, but YouTube says I've reached my daily upload limit. Grr. I'll try to upload them tomorrow.)
Needle plate and feed dogs removed, shot from top left https://youtu.be/gU6iqXo5XkE
Needle plate and feed dogs removed, shot from above https://youtu.be/KzAVHOavvZE
Needle plate and feed dogs removed, shot from above right https://youtu.be/ecs0gZc86z4
Needle plate and feed dogs removed, shot from underneath left https://youtu.be/lTKJZDKKaQY
Have you looked at everything the thread touches and slides across to be sure there's not a burr somewhere? Come to think of it, have you looked to be sure the thread is feeding smoothly from the spool?
- Voltaire
- Aristotle
I'm enjoying learning hidden qualities of the thread check spring. Which of these screws do I loosen on my 341 to effect #1 and #2?
What jumps out at me is that the latch opens abruptly. Not sure if that's normal for this machine. I don't see the bobbin case opener..maybe it's internal?
