Members Jinglin Posted July 15, 2025 Members Report Posted July 15, 2025 (edited) Foil Stamping Temperature Testing: Finding the Perfect Temperature To explore how temperature affects foil stamping results, I tested the hot foil machine using Gold Foil on 1mm thick vegetable-tanned leather at three temperatures: 110°C, 120°C, and 130°C. Here’s what I found: 110°C: The foil stamp was clear and sharp with clean, crisp edges, but the overall effect looked flat, lacking gloss and depth. 120°C: Depth and gloss improved significantly; the design appeared vivid with relatively clear edges, although slight edge blurring was visible under close inspection. 130°C: The foil was thick and rich, but edges became smudged and showed signs of bleeding due to overheating. In summary, 110°C is ideal for precise, crisp results, while 120°C strikes the best balance between depth and clarity. Depending on the material, intermediate temperatures like 115°C are also worth trying. Edited July 15, 2025 by Jinglin Quote Jinglin-Devoted to Crafting an Impeccable Embossing Experience Tiktok YouTube Channel Instagram
Members DieselTech Posted July 15, 2025 Members Report Posted July 15, 2025 It all depends on what leather you are using. Temperature depends on leather choice. Quote
Members Jinglin Posted July 16, 2025 Author Members Report Posted July 16, 2025 6 hours ago, DieselTech said: It all depends on what leather you are using. Temperature depends on leather choice. Yes, I have compiled a table. Please check it out. I hope it helps you too. Quote Jinglin-Devoted to Crafting an Impeccable Embossing Experience Tiktok YouTube Channel Instagram
