I mostly make leather knife sheaths and I was trying to find a compact rivet to end the stitch lines.
I like copper burr rivets, but the smallest available are still way too large.
I have found a solution that works for me.
Amazon sells assortments of metric copper rivets in flat-head and round-head versions.
The range is 2mm, 2.5mm and 3mm shaft sizes
https://www.amazon.com/dp/B0CNCSHG3T
https://www.amazon.com/dp/B0CNCT42XG
I found the washers on McMaster Carr.
They are sold as #1, #2, and #3 copper flat washers
https://www.mcmaster.com/97565A111/
https://www.mcmaster.com/97565A112/
https://www.mcmaster.com/93661A112/
I made my own rivet sets by just end drilling some pieces of 1/4" round steel rod.
You will need a #44, a #40 and a #31 drill bits.
I think mild steel is fine as these will only get light use.
I will probably make some matching doming tools by using a diamond ball bit
in a dremel to carve little domes in some harder steel rod.
2025-07-2522_30_56.jpg.394754de21fa8dc1c900f26f350cf4e4.jpg2025-07-2522_30_48.jpg.71eb24cd8c8d69041a8e3589957075b6.jpg2025-07-2522_30_42.jpg.3613b1b42b6455e7aa5d716dca777e82.jpg2025-07-2522_30_37.jpg.30e673d4b143dc687f3bee4944c70bb6.jpg2025-07-2522_30_17.jpg.5c59162c8c422d42a23aa2d0c8ab3cdb.jpg2025-07-2522_26_51.jpg.6f0985e407ed774f2b95efc2181e98c0.jpg2025-07-2522_26_49.jpg.9b48d2a46d90c9fc97ead51bd4daf356.jpg2025-07-2522_26_46.jpg.9de6d638230b356ae0ea0cc189432eca.jpg2025-07-2522_26_32.jpg.6dc34b06fdf762d3b8e5279c55bebd5a.jpg2025-07-2522_26_29.jpg.9799b238b92a29b17ec1cd38a9e0c1aa.jpg2025-07-2522_26_27.jpg.1b2cf963d71f0059a04338d7e062bbc4.jpg2025-07-2522_25_44.jpg.dc937e20181420327860df1997196afa.jpg2025-07-2522_25_39.jpg.c5825af2e64a6e69b267134c2b9d3e70.jpg2025-07-2522_25_32.jpg.90d0f044fffe28d95299bfb831d90a1d.jpg
Excellent you found a solition for your needs
For a doming tool; before you cut one, there are doming setters meant for ready-rivets which have a domed head already. I have the domed setters in sizes from 4mm to 12mm in 1mm steps
I found the set of doming tools on Amazon
https://www.amazon.com/dp/B0D6724Z62
$30 is worth my time to just buy them.
Innovative solution and good looking results. Thanks for posting this information.
The 2.5mm and 3mm washers do clinch onto the rivet shaft just like Burr Rivets.
The 2mm washers are just a tiny bit too large on the ID, so they don't clinch, but I didn't find that made it any harder to use.
If you bop the washer sideways with a tiny hammer, it can distort the hole enough so it does grab the rivet shaft.
