Members NancyLou Posted August 2 Members Report Posted August 2 I’m sewing webbing onto a cast net using the singer 111w155 which is the only thing in my life that gives me a hard time. I just refilled the bobbins: everything was working up until I did that. It seems to go about 5 stitches then stops abruptly, and all the thread is bunched on the bottom. I have checked threading etc oiled but cannot figure out the WHY. Could it possibly be that there is too much thread on the bobbin? You all have help me in the past and I appreciate it. Is the only bobbin thread adjustment the bigger screw shown in photo? Frustrated in Florida Quote
Members Constabulary Posted August 2 Members Report Posted August 2 why is the bottom thread under the latch of the bobbin case? Always good to read the manual fully (no offense) - I guess you have a manual, right? Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
AlZilla Posted August 2 Report Posted August 2 Hey @NancyLou, i moved you over to Leather Sewing Machines. I know it doesn't seem quite right since you're not sewing leather, but Help Wanted is for people wanting to find someone to do a job, essentially. I don't know why it required moderator approval. We'll keep an eye out for your next post and see what happens. The big screw you mention holds the opener that pulls the bobbin case back to allow the needle thread to pass around the bobbin. Clear as mud, I know. I don't think any of mine are all the way forward, so it could be out of adjustment. Also, the thread being under the lever that holds the bobbin in place isn't remotely correct. Let me go see if I can find one of Uwe's phenomenal videos about how to set that case opener. EDIT: 48 seconds from Alexander Dyer will do the trick, too: Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Contributing Member friquant Posted August 2 Contributing Member Report Posted August 2 Nice photos!! You can check whether bobbin is loaded properly before making any stitches. Install the bobbin and bobbin case cap. Put the latch down (and make sure no thread under the latch!) Bring up the bobbin thread Pull the bobbin thread for a few inches. You should feel a gentle resistance the whole time you are pulling. If it snags, something is not right. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members NancyLou Posted August 3 Author Members Report Posted August 3 Yes thread ends up like photo. After just a few stitches thread gets Bunched up and under latch. After several hours of trying different things it seems to be working again. Thank you for your help Quote
