Members Quetz Posted August 7, 2025 Members Report Posted August 7, 2025 Hi, Hoping some can help me. Ive used the adler before for sewing rubber . But for some reason sewing rubber now the thread bunches up underneath. Ive tried new/ different size and different sort needles. Ive tried to change tension. I'm stuk. Looking forward to some advice thanks Quetz Quote
AlZilla Posted August 7, 2025 Report Posted August 7, 2025 Moved to Leather Sewing Machines since we don't have a "Rubber Sewing Machines" section ... Still a better shot at some help. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Moderator Wizcrafts Posted August 7, 2025 Moderator Report Posted August 7, 2025 8 hours ago, Quetz said: Hi, Hoping some can help me. Ive used the adler before for sewing rubber . But for some reason sewing rubber now the thread bunches up underneath. Ive tried new/ different size and different sort needles. Ive tried to change tension. I'm stuck. Looking forward to some advice thanks Quetz Make sure you hold back the starting threads, or at least the top thread, for about three stitches. Ensure that the needle isn't too small. Move up a size or two to see if that helps bring the top thread up into the leather. Choose the correct size needle for the thread combination. Do standard troubleshooting stuff. Start by checking the hook to needle timing. Adjust the hook or needle bar height if it has been thrown out by the impact of sewing rubber. Remove the throat plate and clean off any residue on the bottom of it. Also, check the feed dog and clean it if necessary. Re-time the machine. Change the needle to a leather point needle. Make sure you've threaded it correctly and that the top thread stays inside the tension disks and doesn't lift up as you sew. Center the check spring if it was turned to one end or the other end. Finally, make sure that there is a modicum of tension on the bobbin thread; not too much or too little. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
