Members fishinmex Posted August 17, 2025 Members Report Posted August 17, 2025 I have been working on a 211G155, I finished setting all the timing of the hook but the cover plate wont close. The plate hits the top of the bobbin. What am i doing wrong? Quote
Contributing Member friquant Posted August 17, 2025 Contributing Member Report Posted August 17, 2025 How about some photos? We love photos 🤩 Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Contributing Member friquant Posted August 17, 2025 Contributing Member Report Posted August 17, 2025 (edited) I assume you removed the hook. When you drop the hook back in, make sure it also drops into the hole of that little piece that moves the bobbin latch opener. If you miss that part, the hook (and bobbin) will be about 1/8" too high, and the screw won't tighten reliably because the hook isn't down where it's supposed to be. It's important not to run under power till you get this sorted. A check for this would be to turn the machine over (gently) by hand and see if the latch opener moves. If the latch opener does not move, then the hook probably isn't down inside that piece. I don't remember exactly what mine looked like that had this problem. This machine Uwe demonstrates on looks more or less foolproof, but I've had a different machine that was quite fiddly to get all the pieces to align so the hook would drop in all the way: https://www.youtube.com/watch?v=CfkGrz3OugA&t=277 Edited August 17, 2025 by friquant Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members dikman Posted August 17, 2025 Members Report Posted August 17, 2025 The bobbin case isn't fitted properly, that tab sticking out is supposed to fit in a notch under the needle plate to stop the case from turning. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
