CowboyBob Posted September 8, 2025 Report Posted September 8, 2025 If you moved the hook to the left you "might" have too little clearance between the tab on the hook base & the cutout underneath the needle plate,you can either open up the cutout on the needle plate or move it slightly to the right. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Contributing Member friquant Posted September 9, 2025 Contributing Member Report Posted September 9, 2025 On 9/6/2025 at 9:23 AM, Karbo said: Thanks, I’m still working on it, I think there’s also a tension issue. How are you and the machine doing? You mentioned a tension issue. Once you start holding the top thread when you start a seam, if there are still loops on the bottom then you need to add more top tension. I should have mentioned that before. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
