Members Numby Posted 10 hours ago Members Report Posted 10 hours ago Hello, Recently acquired and old adler (chandler) 67-gk373. The tension assembly on the front of the machine is a mess, to say the least. To get the original part (0067 000224) it's about $400 canadian. Ouch. Are there any alternative replacements that might work? There is an adler 69 assembly available from Amazon, but unsure if that would work. I tried searching here but couldn't find anything. But that could just be my incompetence at searching. Lol Thanks for your time! Quote
Members Michiel Posted 9 hours ago Members Report Posted 9 hours ago Adler 69 should be the same and i once made an tension assembly of an pfaff 145 fit onan adler 67 Adler 67 68 69 167 168 and 169 all have the same tension assembly Quote
Members Numby Posted 7 hours ago Author Members Report Posted 7 hours ago 2 hours ago, Michiel said: Adler 69 should be the same and i once made an tension assembly of an pfaff 145 fit onan adler 67 Adler 67 68 69 167 168 and 169 all have the same tension assembly Do you have any pictures off the pfaff on the 67? Thanks. Quote
Members Michiel Posted 4 hours ago Members Report Posted 4 hours ago No, sorry later i found an adler assembly and changed it. the paff assembly did fitt but i had to modify it a little bit Quote
