If you want equal lift, here's how to do it.
friquant. Like a frequent, piquant flyer.
Check out my blog: Choosing a Motor for your Industrial Sewing Machine
  • Replies 31
  • Created
  • Last Reply
Top Posters In This Topic
On 9/22/2025 at 3:48 PM, dikman said:
I'm not sure about using an impact driver but the idea of tapping the screw with a hammer is good, sometimes it can loosen a screw just enough to start it moving a bit, then work it back and forth. As for heat if you're using a small pin-point butane torch I doubt if you're going to get it hot enough to affect the hardness.
Thank you dikman!  That is the type of torch I have, so I will keep at it.
On 9/22/2025 at 5:45 PM, DoogMeister said:
Impact drivers are great, but there is considerable risk of bending in the machine if you hit it hard enough to dislodge the screw.  A good soaking with penetrating oil followed by heat with a propane torch combined with an appropriate sized slot and good-fitting screwdriver should work.
You may end up removing everything but the threads of the stuck screw with your Dremel tool.  Go slowly, and have good light and magnification.  Then pick out the threads with a scribe or similar pointed instrument.  Run a thread tap through the hole to clean it out, and replace the screw.  much easier said than done.
Thanks Doogmiester!  Do you think it's a standard thread pitch and size?  I've heard Singer screws are all different types of thread arrangements.  Any suggestions where to buy a new screw?
Thanks Friquant!  I will fine tune it that way and get them equal.
Alzilla, I agree it may come down to drilling....
Will keep y'all posted when I have some time to tackle it this weekend.  Thanks again!!!
Singer (made in USA) should be an SAE thread.  Could be fine or coarse thread pitch.  My local ACE hardware has a tremendous selection of screws, bolts, and such.  Lowe's stocks stainless steel machine screws in size 4-40, 6-32, and 8-32.  A hobby shop that caters to radio control enthusiasts will have small screws in both SAE and metric threads.
Grainger, Fastenall, and McMaster-Carr also stock a wide variety of hardware.  If you can identify the size and thread pitch, a gunsmith may be able to help.
Just watch the banner ads for Toledo Industrial Sewing Machines and give him a call. Bob Kovar will know exactly what it is and probably have it in stock.  Even if it's a standard thread and even if you know it, you won't know the length.
- Voltaire
- Aristotle
Thank you all for your help!  I ended up cheating a little bit and took the machine to a machine shop.  The machinist got the screw out in minutes and didn't charge me.  I asked him how he did it, and he said I had already done all the work for him 😆  I think it was likely a case of having the right selection of screwdrivers to fit the deformed slot, just like you all advised me.  He also is 94 years old and probably has about 85 years of experience.  What a legend!
Since he didn't need to drill the screw, I still have it.  I cut a new slot in the head perpendicular to the old one, cleaned the threads on the screw and on the machine side, and so far I'm reusing the screw and it seems to be fine.
I got the feet lifting equally now, too.  The only things that seem wrong still are:
1. Cranking the machine takes a bit more effort during the part of the cycle when the inner foot is making contact with the work and the needle is down.  I don't see anything binding, it just doesn't feel as loose and smooth as the part of the cycle when the needle is up.  Is that normal?
2.  The pressure foot lift releasing lever (the lever you'd use to raise the feet when beginning and ending your stitch) will lift the feet when the needle is up (and the outside feet are down) but won't lift the feet when the needle is in the work and the inner foot is down.  Any ideas?  I think it's something with either screw A or screw B in the pics I've attached.  The lifting lever isn't contacting the whole assembly it needs to lift when the needle is in the down position.
THANK YOU all again for your advice and guidance.  You guys rock!!
Genius!
Missing lock nut? My singer 144 has a lock nut on that stud.
This is normal. The extra work is going into compressing the presser foot spring. The effect goes away if you lift the presser feet.
Mine does not lift as far when the inner toe is down. Maybe you aren't getting enough lift. Try pressing down with your hand on the far end of the foot lift bar and see if the feet will come up.
It looks like you are missing a screw here.
Thanks Friquant!  You are totally right...I am missing that lock nut and that screw and I didn't realize it.  Uh oh.  Any idea what that screw does?
