Members shug Posted September 22 Members Report Posted September 22 Hi all,I have owned a strap cutter for about 20 years with good service but has now sadly given up on life.i recently bought a cheap one which unfortunately proved to be false economy.i wonder if anyone can recommend a reasonable model in the UK please?thanking you in anticipation, mark Quote
kgg Posted September 22 Report Posted September 22 43 minutes ago, shug said: Hi all,I have owned a strap cutter for about 20 years with good service but has now sadly given up on life. You didn't mention if it was a motorized strap cutter or a mechanical one that you are looking for. ????? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members TomE Posted September 22 Members Report Posted September 22 (edited) For me the type of strap cutter I use depends on the thickness and width of the strap. I use an inexpensive wooden strap cutter for thin leather (<7 oz) and narrow straps (3/8"-1"). The wooden strap cutter is also handy for cutting straps from small pieces of leather. Abbey England sells one that is as good as any I've purchased in the USA. I do sharpen and strop the blade, holding it with a surgical needle holder (heavy duty hemostat). For 6-12 oz straps that are 1/2"- 1" wide I use a draw gauge. @bruce johnson has some nice draw gauges that are ready to use, and a tutorial on his website about how to hold the draw gauge. For heavy and wide straps (> 3/4") I use a plough gauge that I bought from Vergez Blanchard. I did spend some time reworking the angle of the knife blade (~15 deg) and I put a small bevel on the back side of the knife to keep it from pinching the strap excessively against the gauge. It is my go-to tool for cutting lots of straps from a side of 9-10 oz leather. Edited September 22 by TomE Quote
