Members Wyowally Posted September 29, 2025 Members Report Posted September 29, 2025 Trying to help someone who just acquired one of these, but no help or info from the previous owners. New owner isn't experienced. Threading through the tensioner and check spring - parts don't look the same as the parts manual. Check spring has an external little coil along with the standard U-shaped bend. The check spring adjuster/stop has a wide range possible. Timing seems off, Hook/shuttle, bobbin case mechanisms appear sloppy. Any guidance appreciated! Can get pictures later today. Quote
Members Constabulary Posted September 29, 2025 Members Report Posted September 29, 2025 (edited) 2 hours ago, Wyowally said: Check spring has an external little coil along with the standard U-shaped bend does not sound like a 7-34 - just from what I have in mind it sounds a bit like Singer 7-10 (or similar) thread regulator spring - but I´m just guessing... We need pictures I´d say. 😉 2 hours ago, Wyowally said: Timing seems off, Hook/shuttle, bobbin case mechanisms appear sloppy Barrel hooks always appear a bit sloppy cause the thread needs to slide around it. Edited September 29, 2025 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Wyowally Posted September 29, 2025 Author Members Report Posted September 29, 2025 Pictures this afternoon. From the tool marks and screw heads I think this was worked on several times for sure. I'll update. Thanks! Quote
