AlZilla Posted November 5 Report Posted November 5 I can't get that video to run this morning but it sounds like you're talking about what I would call the "case opener". A finger that contacts the bobbin case at exactly the right time and pulls it counterclockwise (in my machines) to be sure the needle thread clears when exiting the tab area under the needle plate The tab keeps the bobbin case from spinning around. If the machine is sewing, it can't be too far off. If the opener was holding full pressure all the time, the thread would hang up on the side where it enters the tab area. That said, it should have some float - I could see it accelerating wear on some parts if it's under even slight pressure 100% of the time. On my machines, the case opener finger itself has a slot on the end, where it screws down. I think there's even a spec to set the clearance. I know that doesn't tell you exactly what to do on your specific machine, but the concept is the same. Unless you're not talking about a case opener. If not, ignore everything I just typed... 😃 Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Moderator Wizcrafts Posted November 5 Moderator Report Posted November 5 3 hours ago, Yoshi888 said: Also not sure it is completely the right term but it's whats referenced in the manual. It is the part on the bottom left of the video that holds back the thread after the hook released it across the bobbin. To my understanding it should be kept there a bit longer so it does not get entangled with the bobbin mechanism. But currently it basically releases the thread instantly after it passes above the bobbin case. That part is known as the "latch opener." It should be set to pull back on the bobbin case as the thread goes around it, then let go after the thread knot is pulled up past the notch in the throat plate. There is a small amount of wiggle room in that cutout for the little tab on the bobbin case/shuttle to move forward and backward. Pulling it back at the right moment frees the thread to go up without hindrance. It should not be set to pull back hard against its stopped position. Leave a tiny amount of clearance at the pulled back position so you don't break anything or wear out the pulled parts. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Contributing Member friquant Posted November 6 Contributing Member Report Posted November 6 Here's the image from the engineer's manual. I don't bother with measuring this adjustment---I just make sure the latch opens far enough to allow thick thread pass through, and make sure the latch doesn't bind. By the way, it's the needle thread that goes through the latch, and the latch should open to allow the needle thread to go through as soon as the needle thread is ready. (Otherwise there will be some popping sounds as the thread gets forced through a closed latch) Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members Yoshi888 Posted November 18 Author Members Report Posted November 18 Sorry for my late replies, I currently have quite some things to do, so I can only work on the problem from time to time. Thank you @Wizcrafts for the info about terminology that helps a lot to specify problems more accurately. I have done the adjustment again, so the gap between the two parts is as small as possible, but the latch opener still releases the thread somewhat early. It works, but I don't think it is ideal. While I was playing around with the fine-tuning and adjustments, it seems I managed to trigger the safety device that disengages the lower drive shaft. I assume the way it should work is that when a certain force acts on the hook the wheel should slip so it does not break the hook or other parts. I have checked the Engineering Manual, and from what I can gather after repositioning the lower shaft, it should engage again. But it seems to slip off very easily and thereby does not turn the lower axis properly. Is there another step I am missing to engage the safety mechanism again properly? Once again, I have attached a video to better illustrate the issue. Thank you all for the help. I am getting better and better at solving those things 😇 PXL_20251117_155311108 (1).mp4 Quote
Moderator Wizcrafts Posted November 18 Moderator Report Posted November 18 51 minutes ago, Yoshi888 said: While I was playing around with the fine-tuning and adjustments, it seems I managed to trigger the safety device that disengages the lower drive shaft. I assume the way it should work is that when a certain force acts on the hook the wheel should slip so it does not break the hook or other parts. I have checked the Engineering Manual, and from what I can gather after repositioning the lower shaft, it should engage again. But it seems to slip off very easily and thereby does not turn the lower axis properly. Is there another step I am missing to engage the safety mechanism again properly? There should be a push button somewhere on the bed of the machine. You push down on it while rotating the balance wheel backwards until the safety clutch mechanism connects, with a noticeable sound. If the safety clutch engages too easily, there may be adjustments on it to stiffen the action more. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
