Members TakashiOkada Posted November 21 Members Report Posted November 21 I don't know the correct name of this part in english but I need to replace it and I can't find anybody that sells it in my country so I'm looking to buy it online from the US, europe or china. can't google it because I don't know how it's called. https://www.ebay.co.uk/itm/380810963466 This is what I've found but I need number 5, not 7. Quote Typical TW3-343 | Typical TW5-810 | Singer 29K171 | Seiko TF-5 and TF-6 | SunStar KM-380BLB | Singer 45K (?) | Adler 30-7
kgg Posted November 21 Report Posted November 21 10 hours ago, TakashiOkada said: This is what I've found but I need number 5, not 7. You probably get better help if you listed the manufacturer of the machine. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members TakashiOkada Posted November 21 Author Members Report Posted November 21 4 hours ago, kgg said: You probably get better help if you listed the manufacturer of the machine. kgg sorry, here are some pictures. Quote Typical TW3-343 | Typical TW5-810 | Singer 29K171 | Seiko TF-5 and TF-6 | SunStar KM-380BLB | Singer 45K (?) | Adler 30-7
kgg Posted November 21 Report Posted November 21 24 minutes ago, TakashiOkada said: sorry, here are some pictures. The photo with the nameplate info appears to be for the motor which was made in Croatia. The wording "tvornica elektricnih strojeva subotica" converts to say "Electrical Machine Factory, Subotica". I would send your photo's to USM ( https://usm-americas.com ) and see if they could match up something. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members TakashiOkada Posted November 21 Author Members Report Posted November 21 2 hours ago, kgg said: The photo with the nameplate info appears to be for the motor which was made in Croatia. The wording "tvornica elektricnih strojeva subotica" converts to say "Electrical Machine Factory, Subotica". I would send your photo's to USM ( https://usm-americas.com ) and see if they could match up something. kgg thank you! 🙌 Quote Typical TW3-343 | Typical TW5-810 | Singer 29K171 | Seiko TF-5 and TF-6 | SunStar KM-380BLB | Singer 45K (?) | Adler 30-7
Members Tastech Posted November 23 Members Report Posted November 23 @TakashiOkada Your internal measurements almost correspond to a Landis blade. I am getting the measurement of 19.4mm on the internal on my landis blade . Search for Landis or Sutton . They are interchangeable . I believe the British machines also take the same blade measurements . Now lets talk about saftey of your machine or lack there off .That blade needs a safety guard. You are one slip away from losing a finger and thumb . I saw it happen 30 Years ago to a co worker . His hand was a mess and he never worked again . Just looking at your machine gives me PSD and makes me feel weak in the stomach . Please do something about it .Please Quote
Members TakashiOkada Posted November 23 Author Members Report Posted November 23 13 hours ago, Tastech said: @TakashiOkada Your internal measurements almost correspond to a Landis blade. I am getting the measurement of 19.4mm on the internal on my landis blade . Search for Landis or Sutton . They are interchangeable . I believe the British machines also take the same blade measurements . Now lets talk about saftey of your machine or lack there off .That blade needs a safety guard. You are one slip away from losing a finger and thumb . I saw it happen 30 Years ago to a co worker . His hand was a mess and he never worked again . Just looking at your machine gives me PSD and makes me feel weak in the stomach . Please do something about it .Please so, blades for landis, this could definitely help me find it. wow I had no idea this machine should have a guard. I'll check tomorrow if It has some slot or hole to screw one onto the rod or some other way to install it. let's hope I can use a landis guard as well. thanks! Quote Typical TW3-343 | Typical TW5-810 | Singer 29K171 | Seiko TF-5 and TF-6 | SunStar KM-380BLB | Singer 45K (?) | Adler 30-7
Members Tastech Posted November 24 Members Report Posted November 24 @TakashiOkada. Here is a photo of the guard. It is aluminium. it slides over the shaft and covers the blade it can be moved left or right using the allen key screw to only expose the amount of blade you use . It's not hard to make if you know a machinist . I get my blades from Leffler in Melbourne Australia . They are the Landis agent here . The link is an example of what they have . search on their site for Landis sole trimmer blades. They have many variations . They also have various size trimmer shields for when the blade loses its diameter because of sharpening https://www.leffler.com.au/trimmer-sole-5mm-/ There is also these guys in the UK . I am pretty sure that the british standard sole trimmer blades and the Landis blades are compatible with each other https://www.standardgroup.co.uk/shoe-repair-machines Keep in mind that i know for a fact that Chinese blades only fit Chinese machines . the internal diameter is different . The made in china machines are actually pretty good to use . The only drawback is the blades and brushes are only available direct from their factory and not interchangeable with British , American or Australian machines Quote
Members TakashiOkada Posted November 25 Author Members Report Posted November 25 @Tastech I was having a hard time finding a close up picture of a guard, this is really helpful. I think this will be enough to have someone make me something similar. I can't buy from australia so I'm gonna check the uk source. thank you! Quote Typical TW3-343 | Typical TW5-810 | Singer 29K171 | Seiko TF-5 and TF-6 | SunStar KM-380BLB | Singer 45K (?) | Adler 30-7
