Members cocuzza Posted December 17, 2025 Members Report Posted December 17, 2025 Hello everyone, I recently bought my first skiving machine, it's a used machine, a Sagitta SC75A (for which I'm also looking for the manual) I'm new to skiving so I'm asking you if you've encountered problems like mine and could you explain to me how I can solve them? The big problem is that it flakes unevenly with a wavy pattern, not smooth as it should be. Thank you Ps, I'm attaching a photo to help you understand the problem. It's a 2cm wide and very long strip of leather, stripped from 1mm to 0.5mm. Quote
Members TomE Posted December 17, 2025 Members Report Posted December 17, 2025 I'm no expert but I would sharpen the knife, working slowly/gradually to avoid overheating. Use a marker on the bevel to see that the stone is creating a uniform bevel. I would also polish the foot to reduce drag - use a buffing wheel if you have access to one. Check that the drive roller is round and without gouges/flat spots by shining a bright light to visualize the gap between the roller and the knife. Quote
Members FDC Posted December 24, 2025 Members Report Posted December 24, 2025 I agree with Tom, first thing is to get your knife razor sharp! Then adjust the feed wheel and presser foot to suite. Quote
