Members D.jsherwood Posted 4 hours ago Members Report Posted 4 hours ago Hello all. I just joined here to ask you all gor advice on what machine to get. I dont have much, I really can only go up to about $650 on the machine itself, and I need it to redo a boat interior, so, vinyl. It seems as though each time I find one I think would work, I see one you all or folks elsewhere saying not to get it. Quote
AlZilla Posted 4 hours ago Report Posted 4 hours ago More experienced voices will no doubt chime in here but you should be able to get into a used machine with that budget. A tight budget, for sure and your may end up with a fixer upper, but doable. I'm thinking something in the range of a Consew 206RB-x (x being a number up to 5), or one of it's many equivalents. Start fishing what you find past the experts here and you'll probably get great advice. I'd only suggest holding out for something with reverse. You don't need it and not having it will save you money. But you'll experience a feeling of lack every time you use an older method to lock your stitches. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Moderator Wizcrafts Posted 4 hours ago Moderator Report Posted 4 hours ago 17 minutes ago, D.jsherwood said: Hello all. I just joined here to ask you all gor advice on what machine to get. I dont have much, I really can only go up to about $650 on the machine itself, and I need it to redo a boat interior, so, vinyl. It seems as though each time I find one I think would work, I see one you all or folks elsewhere saying not to get it. You'll need a walking foot machine for this job. It could be a portable walking foot machine made by Sailrite. Or, it could be an industrial machine head mounted on a 20x48 inch table with a clutch or servo motor under the table. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Contributing Member friquant Posted 2 hours ago Contributing Member Report Posted 2 hours ago Pfaff 545 is a flatbed with triple feed (aka walking foot) that I see come up on marketplace for $600 - $800. That's what I bought as my first machine. It's biggest fault for me was the stitch length only went up to 4mm. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
