Members docpugh Posted January 31 Members Report Posted January 31 I recently acquired a Singer 17-30. It has a feed dog but no needle plate nor needle/throat plate holder. I found the needle plate I need and ordered it. I can’t seem to find the throat plate holder, Singer part #16879. Does anyone have an idea where I might find one or an equivalent to fill the role? Thanks. Quote
AlZilla Posted February 2 Report Posted February 2 Toledo Industrial Sewing Machines would be worth a call. Tolindsewmach.com I needed some pretty obscure parts last year and they had them in stock. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members Cumberland Highpower Posted February 3 Members Report Posted February 3 (edited) That's pretty tough. You're essentially going to have to find someone with a junk 17-30 that can supply you with parts. How handy are you with tools? If you have a drill press and belt sander/grinder you can made an adapter for it, something that can screw down with the large screws and then fit a needle plate from a different variant on top of it. For example, a needle plate from a Seiko TE series machine. (Chinese needle plates for the TE can be found fairly easily and not expensive). I've made/fit needle plates a few times over the years, it's not as hard as it sounds. You might also be able to change the shuttle race plate with one for a TE Series machine and then use a TE needle plate. But I don't know if they're fully interchangeable between a Singer and a Seiko? Of course that may not be something you may not be interested in, or maybe, I don't know. Then again, it may not be really worth any serious investment? I don't know what your machine is worth to you. I could see $200 worth of parts/labor on a $30 machine being a deal breaker. Edited February 3 by Cumberland Highpower Quote
