I have had a saddle tree hanging on the wall in my shop for a couple of years. It was square when I got it but, when checking today I found out that somehow it has warped. When I put it on the bench one of the corners is about 3/8" above the bench surface. A couple of questions : How much warpage can be tolerated ? Is there a way to correct it? What would you do?
Another interesting question is :Would the tree have warped if I had built a saddle when the tree was new ? and how many horses have saddles on their backs with warped trees?
"The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Three-eighths would be too much for me to spend the time to cover it. I'd check some other measurements like diagonals to see how far out it is in other aspects. I haven't jumped on one or torqued one to square it up so can't help you there.
One guy I have talked with would not build on a rawhided tree until it sat for 6 months in his shop to cure. I don't know how other guys handle it, they ususally sit around a while for me too but not for a set reason. I am sure there are trees that warp over time, we've probably all seen that.
I think Rod mentioned this in one of his replies a while back, but I have seen it also. I took a tree to a swap deal and it sat on the bedliner of my truck in the summer for a few hours. It was dead on level at my house. After it heated up it had about a scant 3/16" rock. I put it in the guy's shop and within an hour it was level again. Heat will affect one.
Bruce Johnson
Malachi 4:2
I would agree with Bruce that this tree would be unusable. I think that anything over 3/32" will throw the angles front and rear out of alignment to much. Two things I do to keep everything as stable as possible is to laminate all parts, including the bars, and to encase the structure in epoxy resin with at least one layer of fiberglass cloth on the top of the tree before it is rawhided. To my knowledge I'm the only maker laminating bars, and yup it takes much more time, but I believe it is well worth it.
Jon
Jon; Ben Swanke laminates his bars as well. greg
Jon
I also laminate my bars to give them more stability. Just cut out 4 pair today
I also figure any more than 1/8 of rock is too much. that being said with trees that are not made to stringent precise standards ,they may or maynot be square even when they sit square.. That is maybe a little confusing but I have certainly found it to be the case.back when I used factory made trees.. That is one of the reasons I learned how to build my own.
It can be either the rawhide twisting the tree and it may be the wood twisting the tree.
I have years ago wrapped a tree in wet towels to soften the rawhide and then clamped the tree past square and then let it dry then put weights on it for a few weeks., Then let it sit for a few weeks . If it remains stable and square..and your comfortable with it.........
Edited by AndyKnight
Andy knight
Visit My Website
Andy,
I'm glad to know you and Ben are laminating bars also. I've had some makers actually snicker at the fact that I'm doing such, but have always believed it was worth the extra effort. You are also correct in stating that a tree can be out of square even if it is sitting square on a machined surface. This is why I build my trees from the bottom up, not allowing the leg cuts on the front to be the absolute determining factor for position of the bars. I know most makers get along OK building from the top down, the issues I encountered didn't favor absolute precision.
Jon
Andy,
Jon
Jon
How do you put the tree parts together, do you use screws, nails or staples ? I have a feeling that a poor assembly will have a great deal in the warping process, when the rawhide starts to shrink.
We would agree that to start building on this tree with that much twist is not a good thing, though when you pull old trees out of saddles it is sometimes "interesting" what you find. Agreed that it can not rock on a stone and still be crooked, and if it is built straight a 1/8" difference is not going to matter much, since it practially means that you have 1/16" difference on each side of the horse. Don't know many horses that are built that symmetrically.
We laminate some bars and not others, mainly to use wood efficiently. When we first started we didn't pay much attention to grain direction in the bars, but we soon started to make sure they were similar and we thought we had less problems keeping trees straight as they dried. Then I started keeping track of grain directions in the bars and if they were laminated or not so I could correlate it with whether they tried to go a bit off or not. There honestly doesn't seem to be a correlation. The laminated bars are just as likely as the non-laminated ones to rock a tiche according to my records. That doesn't make logical sense to me, but it is "real life" data. (We use screws and glue to put the tree together.)
Something you may want to try is to weight the tree down on a flat surface with a bit of a shim under the side that connects so you have made it rock worse. Leave it for a while - weeks - and see if it changes. If it goes back to being an "acceptable" amount of rock, take the weight off and see what it does over more time. If it stays there, great. If it gets bad again, then enjoy using it as a demo of what a tree looks like. Humidity and temperature both play a role and trees will go back and forth a bit. It is when they go way off and stay there that they cause problems. I do wonder what happens inside a saddle on the back of a sweaty horse on a hot, humid day versus a cold dry one.
"Every tree maker does things differently."
www.rodnikkel.com
I wonder what would have happened if I had built the saddle when the tree was new and straight , and then kept the saddle in my shop under the same conditions as the tree? I think I would have had a warped saddle!
Oldtimer,
My bars are fixed stationary in my jig, and the cantle and fork are epoxied in place. After the epoxy has set for at least 8 hours, I then run 2" heavy, coated deck screws into the fork and cantle.
Jon
