where do I find Master's?
Thanks,
Doug
TANDY carries the Masters and Masters Solvent
JOhan
****Afrikaans: Leerwerker *****  ****Zulu: lesikhumba isisebenzi  Latvian: ādas darba ņēmējs *****Russian: кожа работника ****English: Leatherworker ****Dutch: Lederbewerker ****Flemish: Leerbewerker ****Hebrew: עור פועל ****German: Leder Handwerker ****Hungarian: Bőrdíszműves ****Turkish: deri işçisi ****French: Artisan du Cuir ****Spanish: Artesano de Cuero ****Norwegian: Skinn kunstners ****Swedish: Läderhantverkare ****Greek: δερμάτινα εργαζόμενος  Sotho: mosebeletsi oa letlalo
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
R H products that makes Duall 88 makes a cement called XL8. It is not quite as fast, but the bond is much stronger, and it will stick to oily surfaces. Is thin and penetrates well for a pre-wetting coat. Takes a bit to get used to as it works different than barge or masters, but I like it the best of all cements on the market. Keith
Keith,
What I like about Duall is that it works well and the fumes aren't too strong. I like that XL8 has an even stronger bond. Are the fumes very strong with the XL8?
Ed
  • 2 weeks later...
Keith,
Ed
Just got the xl8 in. Fumes are much stronger than they are in the Duall 88, which looks and smells a lot like weldwood.
ed
I know some you you really like barge but I will never use it again, simply because of the problems I have had in the past about it not sticking to wet leather. I have been using Duall 88 for the last couple years with great results. I find that the Duall 88 does not have to be thinned like the barge had to be. It remains the same consistancy from gal to gal. I have used Masters before and it works very well but the fumes it puts off is something else. I work in my basement and the exhaust fan will not draw out the Masters without it going through out the house. You also have to have a tax ID to buy Masters.
Randy
Randy,
Where are you getting your Duall #88 in the gallon? I just tried the xl-8, and I think the #88 is better.
ed
Keith,
Ed
My first impression with the xl-8 is that it doesn't provide a stronger bond than the 88 does. Maybe it provides a stronger bond over time.
ed
