Members DOUBLETAP Posted May 14, 2015 Members Report Posted May 14, 2015 Great info here.....I am quickly discovering new things and I'd like a versatile machine that can do wallets, belts and holsters. Will these machines work good on thin leather for wallets as well? i'd hate to have to buy two machines if the lighter leather is too 'light'. Quote Y'all be safe!!! www.firegroundleather.com
Moderator Wizcrafts Posted May 14, 2015 Moderator Report Posted May 14, 2015 (edited) Great info here.....I am quickly discovering new things and I'd like a versatile machine that can do wallets, belts and holsters. Will these machines work good on thin leather for wallets as well? i'd hate to have to buy two machines if the lighter leather is too 'light'. Lol; you just responded to a topic that has been dormant since 2009; six plus years ago. Still, the question is valid. You want to know if a "441 clone" can be used to sew wallets, as well as holsters. As the owner of a Cowboy CB4500 I can tell you that they can, if you make several important adjustments first. These are huge, heavy duty sewing machines that are built from the ground up to sew harness, holsters, sheaths, saddles and heavy straps, bags and cases. The current crop are able to clear and sew up to 7/8 inch of leather, using a needle the size of a roofing nail. They are normally adjusted to properly tension thread that is a half millimeter in diameter (#277), which usually requires at least 1/4 inch of leather to conceal the knots. The tension, pressure and check springs are extremely heavy duty, which this thickness of thread calls for. In order to convince a 441 type machine to sew nicely into 4 to 6 ounces of wallet leather takes all of the following changes: Replace the usual #25 system 794 leather point needle with a #19 system 7x3 round point needle, which is the smallest size normally stocked and sold in the US and Canada for 441 machines. Re-thread the top and bobbin with #69 or possibly #92 bonded thread. The 441 machines are normally sold with #277 thread, which is 4 times thicker. Tighten the bobbin tension spring to get some back pressure on the bobbin thread (but not so much that it puckers the bottom leather). A bobbin set for #277 will just let #69 thread flow with zero tension. Back off the top tension to balance the knots inside the leather. If you find it impossible to get the knots to sink below the top, it may be due to how the top thread is fed from the spool to the top tension disks. A direct path through the top post is usually called for with tiny thread, as opposed to the once around with heavier thread. If you still cannot lower the knots into the leather, the check spring tension will need to be backed off. It is normally set to stiff action to maintain tension of heavy thread. After all these adjustments, if the leather on the bottom is fairly soft and gets pushed into the huge hole in the feed dog, or the equally huge cutout in the throat plate, you will need to remove them and replace the throat plate with an optional narrow slotted plate (and no feed dog). The top pressure will need to be backed way off. The amount of alternating height of the feet may need to be reduced The point of impact of the inside foot will have to be reset to equal the tip of the needle at the surface of the thin material. Otherwise, the reverse stitches probably won't match the forward stitches. Those are the typical changes needed to get a 441 clone to properly sew thin leather. They will need to be reversed to sew thicker leather, with thicker (normal) thread. Edited May 14, 2015 by Wizcrafts Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Darren Brosowski Posted May 14, 2015 Members Report Posted May 14, 2015 Agree with Ryan. In general all of the dealers here have a great reputation for customer service and the prices are not that different so it is more an issue of finding the dealer that is closest to you.All else being equal the closest dealer will be the one to take the machine to in the very unlikely event that things go horribly wrong or simply the closest place to go for instrucrion. Darren Quote
Members DOUBLETAP Posted May 14, 2015 Members Report Posted May 14, 2015 LOL I didn't even think to check the date on it before I posted, but thanks for getting back to me so quickly. Fantastic information, to be honest a bit overwhelming. I don't think I'll need something as big as the 4500...would the same principles/steps apply if I were to get a smaller one, i.e. 3200, 3500..(?). I think the smart thing to do would be to see who and where the 'local' dealer is and make contact to see what machine I need to buy...that 4500 looks beautiful but it's rather big for my workspace and wallet hahaha I really appreciate y'all...and I will most likely hit you up when I do in fact bite the bullet and buy my machine...it won't be long at all. Quote Y'all be safe!!! www.firegroundleather.com
Moderator Wizcrafts Posted May 14, 2015 Moderator Report Posted May 14, 2015 I don't think I'll need something as big as the 4500...would the same principles/steps apply if I were to get a smaller one, i.e. 3200, 3500..(?). Yes. They are basically the same type of mechanism and design. The 3200 just sews less thickness (1/2") than the 3500 and larger. They all share the enormous throat plate cutout and feed dog. You would probably be better off with a CB341 that Toledo Industrial is just starting to sell. I haven't seen one yet, but he says they are clones of a Juki LS-1341, but less than half the cost of a Juki. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
