Contributing Member UKRay Posted April 19, 2009 Contributing Member Report Posted April 19, 2009 I place all the letters next to each other using a dummy letter if the letter repeats itself in the name. I punch the letter nearest the center first and leave the dye in place. I work my way out from center keeping the dye I have just stamped in place in order to butt the next letter up to it. This keeps things straight for me. How do you get on when you need to use the letter I? I find the spacing is completely out if you simply put one letter next to another - a few tips would be appreciated. Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Members somewhereinusa Posted December 14, 2009 Members Report Posted December 14, 2009 I've been struggling with this, since I had eye surgery I can't see if something is straight. (long story) I can tell if it's misaligned after the fact, but not while I am doing it. I have been thinking of making some kind of jig, but that's an outdoor project and it's cold out there. Today I think I have found the answer quite simply. The jig can come later. Since the base of the letter isn't the same distance from the edge on all letters you have to align the letters themselves. I used a thin piece of plastic (cut from some packaging material) make sure you have a straight edge. I clamped a yardstick to the bench, then taped the plastic to it. Slip the leather piece under the plastic and align the LETTER to the edge of the plastic. I also got my design stamps in a straight line without having to scribe a line. This is the first time I EVER got the letters in a straight line. Quote
Members McJeep Posted December 14, 2009 Members Report Posted December 14, 2009 Cool idear! Quote "I gotta have more cowbell!" Cristopher Walken - SNL
dirtclod Posted December 14, 2009 Report Posted December 14, 2009 Ray if i have to use a I . Lay all of the letters out and measure them to find the center. Then i make a small mark in the center of where they need to go and start in the middle and work to either side. Works for me. Quote I'm old enough to know that i don't know everything.
Members laney1566 Posted December 30, 2009 Members Report Posted December 30, 2009 (edited) I use the letters themselves to determine spacing. I leave them setting in the groove when possible when tapping the next letter in. I will use dummy letters if a word has more than one occurrence of a particular letter. Start from center and work your way out. Place the entire word (dummy letters included) before starting with the center letter. Make sure all letter stamps are square. I have had to take files to slightly knock off burrs and ridges. Edited December 30, 2009 by laney1566 Quote
