I find that if you are braiding a 4 strand braid in 1/8" kangaroo, that you will need a hole with at least a 3.2mm hole, though it will be very tight. I try to buy beads with a 3.5 mm hole.
Karen
Karen
thanks karren that helps.
No it isn't easy, but if you are looking on-line, sometimes they say. If they don't, you can contact the site and ask the hole size. If you are looking for a hole that will be tight, just be aware that even though the stated size might be 3.2 mm, it could be a liitle smaller. Therefore, I always like to go a little bigger. Also, if you are looking at beads with a 3.2 mm hole, you can't string a braided portion, you must thread unbraided strands and then start braiding again after the bead is strung.
Karen
Karen
Oh, well that's good to know, thank you very much. I don't want any section not to be braided. I would rather go a little larger as I can add braided beads. I like the looks of the leash pictured above but I found a couple more universal tube beads I like, for those not to into the western look. And I did email one company. Again thank you very much.
Edited by entiendo
I too use a simple turkshead knot to secure my beads. However, if the bead I am using fits very snugly, then I don't bother.
Karen
Problem with that is that the leash can stretch, and when it does, it usually thins out as well, which could leave the owner of the leash with beads that wander. My customers are pretty picky about where they want the beads located, so I put stopper knots to both sides of bead/bead clusters to ensure that they stay put.
Tony S.
Courteous K9 Accessories
I prefer to buy my beads in person. I take sample braids (4-strand uncored, 4-strand cored, and 6-strand double cored) and check that I can get the beads on them.
Tony S.
  • 1 month later...
Hi there. Pretty much new to braiding and only mastered the 4 plait braid. I love the way the beading looks on this piece so can someone direct me on where I would find instructions to create the stopper knot to hold the beads in place?
Thanks and definitely learning lots from this forum group.
If the bead hole is too small, a bead shop will carry a bead hole reamer which will aide you in enlarging the hole to fit the finished braid.
:yes:
Best Regards,
Brian Kidd
  • 1 year later...
Can you tell me exactly how to make this turks head knot ?
Karen
there is a tutorial pinned in braiding on turksheads...in the example shown at the beginning of this topic the center knot is a pineapple knot, which is a turkshead with an interweave, done over a bead to give it size and shape. then the two knots that are on either end are simple spanish ring knots. ring knots are very easy to do, hardest thing is not breaking the lace when you tighten them . then you simply use smooth jawed pliers to make them flat and push them up against the bead.
TRACY
MONSTER FARM SPECIALTIES-custom tack for dog, horse and human
