Tkleather1
slicker
I am also interested in either purchasing or making a slicker. Are the best ones made of glass? where would I find one and can one be home made? does this help alot in the tooling? I do quite a little bit of tooling but have never slicked leather before tooling or carving.
I hope that Hidepounder and others like him can help me in the process that they use to prep the leather before the tooling process as their work is outstanding. I know that there is more of you than just hidepunder but he is the first one to come to mind. I hope I dont offend anyone by not mentioning you by name but all of you outstanding carvers I would sure appreciate it if you could walk me through your whole proccess of casing and slicking and what not. I think it will help me get to the next level as I am still a lot of steps away from your levels.
Thanks
Hi Tk,
The slicker, helps alot in the prep. for tooling. It helps to even out the surface, & close the pores, somewhat, making the leather more even & consistant while tooling. I've also found that a piece that has been slicked & cased, will hold moisture longer, that a cased piece that hasn't been slicked. Which is a good thing! Also, it seems to me that a slicked piece just seems to carve better, & smoother. Plus, in the process of slicking the leather, you are also adhearing it to the backing better. My proceedure is: applying the anti stretch backing, wet the leather, slick in all direction, re wet the leather, & case. If somebody does it differntly, Please let me know. Ed
P.S. I made my slicker about 30 years ago out of 1/4" Lexan, with a leather half wrap.
