Members woolfe Posted April 6, 2009 Members Report Posted April 6, 2009 (edited) These are 8-32 size threads. Aye, but will the head of a 8-32 screw fit inside the male end of a line 24 snap. For example, I'm currently using 6-32 screws and 6-32 t nuts and the head of a 6-32 screw fits just right in side the line 24 male snap and the DOT snaps. Sorry I wasn't very clear. THanks!!! Edited April 6, 2009 by woolfe Quote http://www.woolfegunleather.com/
Members Shorts Posted April 6, 2009 Members Report Posted April 6, 2009 Aye, but will the head of a 8-32 screw fit inside the male end of a line 24 snap. For example, I'm currently using 6-32 screws and 6-32 t nuts and the head of a 6-32 screw fits just right in side the line 24 male snap and the DOT snaps.Sorry I wasn't very clear. THanks!!! No idea. I use screw studs. Quote
Members BOOMSTICKHolsters Posted April 6, 2009 Members Report Posted April 6, 2009 Only 8x32 Flat Undercut machine screws will fit in the DOT snaps. Quote
Members cazio Posted April 6, 2009 Members Report Posted April 6, 2009 Only 8x32 Flat Undercut machine screws will fit in the DOT snaps. I use 6x32 in my dot pull the dot fasteners and the fit fine, I will have to try the 8x32 and let you know. Quote
Members BOOMSTICKHolsters Posted April 6, 2009 Members Report Posted April 6, 2009 If you try to use normal size 8x32 screws in line 24 snaps, you will flare out the top of the stud making the snap very hard to undo. Pull the DOT snaps have even less room to accommodate the screw head. Quote
Members 1Man Posted April 6, 2009 Members Report Posted April 6, 2009 (edited) this works for the male piece of Line 24 snaps. McMaster-Carr part number 92220A152. Edited April 6, 2009 by 1Man Quote www.wardleather.com
Members woodandsteel Posted July 23, 2011 Members Report Posted July 23, 2011 (edited) No idea. I use screw studs. Monica, are you using the DOT line 24 snap screw studs for attaching snap loops ? 8-32? Edited July 23, 2011 by woodandsteel Quote
Members Shorts Posted July 24, 2011 Members Report Posted July 24, 2011 Monica, are you using the DOT line 24 snap screw studs for attaching snap loops ? 8-32? Yes. Quote
