Members jbird Posted April 24, 2009 Author Members Report Posted April 24, 2009 Tina Thanks a lot. Kate Thank you. Josh I will try my hand at it. Quote Josh Dusty Chaps Leather & Seven O Saddle Shop 801-809-8456 Keep moving forward! On a horse. Hebrews 4:12 My link
Members dcobranding Posted July 4, 2014 Members Report Posted July 4, 2014 (edited) Can be made using gray paper and "blowing out" (over-exposing) a portion of the backdrop, or underexposing a portion of a white backdrop by position of the light. A softbox over your light [which creates a larger light source] is most handy to do this. [EDIT: A strobe type light is also highly recommended because it's nearly impossible to get enough light on the subject with a "hot light" (the kind that are constant light).] Edited July 4, 2014 by dcobranding Quote
Members ConradPark Posted July 13, 2014 Members Report Posted July 13, 2014 You can easily do this with two light boxes, I bought a cheap two box set for £40 on ebay that works perfectly for me. Try one directed from the left corner in a 45 degree angel a bit away from the subject and one from the lower right corner directed almost from above. Use ordinary oven aluminum foil to get light bouncing/reflecting back from the sides. I would also say that the picture been heavily modified in a photo editing software, especially the background, while it's not difficult to achieve the affect, the difficulty is to make it look the same on all different products - hence it's easier to do a graded background in a software that you insert on every pic. Quote
Members Pinsplitter Posted December 21, 2014 Members Report Posted December 21, 2014 If you want to get a little bit serious. The traditional studio Light Table looks like this pic. It is transluscent perspex on a frame. In the old days of using film, "contouring" or "deep etching" to take out the background added cost to the customer, so you had to shoot the thing with a clean or graduated background that did not need any extra work on the film. The basics of a white background is to have the light under the table twice as bright as the top lights (plus any side lights you might use), this is a "1 stop" difference in light levels. If the bottom light is too strong the edges of the product will flare out a bit and look weak. The product would be sat up on a block, maybe 2-4 inches high that can't be seen from the camera angle. The curve of the background perspex will give you an even graduation from white to grey, or add another light to keep it all white. If your product is small you don't really need any of the curvy bits (the front down curve is only necessary if you shoot from a very low angle btw.). To make it really simple for a small product just two flat sheets of perspex could be used as in the RHS pic, making a V shape, get the top piece very close to the product, right over it, you should imagine the product is a mirror (it actually is as far as light and camera is concerned) so the top piece fully "covers" the product. White reflectors, card or foam sheet, can be placed on the right and left sides vertically as well. You could do it with just 2 lights, strong ones 500 watt at least, 4 would be better, 2 top 2 bottom for even light, in Aus they sell "work lights" at hardware stores pretty cheap, tungsten-halogen lights in a square metal box, they would work pretty good. The right and left sides can have more perspex pieces instead of reflectors if you want more light control with a light directed through each one. This will be good if you are not a Photoshop expert, the pic will be fine to publish without more work, even if you can Photoshop a very clean white background helps to "contour" the product with the Pen tool, or even just Magic Wand the background to delete it if you are in a hurry. A large example of the same technique is using a full Cyclorama, basically a white room with curved corners and just one open side for the camera and to get the product in, used for cars and also for very "high key" fashion shots, you can achieve very flat lighting so skin imperfections etc are almost removed. That car pic is unretouched shot on film. Quote
Members dcobranding Posted December 21, 2014 Members Report Posted December 21, 2014 Nice work Pinsplitter. Thanks for the info. Quote
