I've been working on a holster for my dad. Everything was coming together great until the last step.
I applied some Eco Flow Leather Sheen with a cloth, and it came out okay, but I wanted a glossier finish, so I bought some Fiebing's Leather Sheen in a rattle can and applied a few coats.
Disaster.
It dried unevenly, leaving ugly splotches all over the blace. I buffed on it with a rag a few times and reapplied. Same problem. Then, being a newbie, I sorta panicked and tried to wipe the coating off. Some came off easily, some didn't, and now I have a massive acrylic mess all over the holster.
1) Is there any way to remove that stuff and start over without damaging the leather?
2) How do I keep it from happening again?
Thanks!
Disaster.
Thanks!
Deglazer from Tandy's should do it. I takes off Neat Lac.
I was told that the acrylic spray on sheen can be removed with warm water on a sponge.......then a dry rag......i have not tried it yet though........
Actually, what you need is acetone. I think it runs about 7 bucks a qt at lowes or Home Depot or wherever, and that's about all Deglazer is. And you get a qt instead of 4 oz for too much money. It would be good thing to condition your leather after you get it stripped tho.
Best wishes! :)
Kevin Hopkins
Best wishes! :)
Kevin Hopkins
Thanks, I'll give that a shot. I had a feeling the deglazer would be similar to acetone anyway, but it's good to have another opinions as well.
  • 3 weeks later...
So can anyone tell me why the rattle can product (Fiebing's Leather Sheen) keeps making white streaks on the leather? I make very short burst of spray. They are visible even when I spray very lightly. Please help.
I hate the way that the rattle cans spray they are very uneven. I hate even more that we have to resort to them since there is no more Neet Lac. what I have been doing is spraying it liberally onto a peice of shearling and applying that way, I get a way better finish.
THAT'S a good idea, Tim!
fonzman,
I use saddle lac all the time and have never had any trouble with it at all. I spray it on, let it set for 15 minutes put a second coat on and once in a while I`ll put on a third coat.
It`s entirely possible that you got into a bad batch or a can with a bad nozzle. I buy by the case if that tells you anything, try it on some scrap leather and see if it doesn`t work-out for you. Keep in mind that you should try out new things on scrap before you use it on a finished product. Good luck!
rbrooks
  • 1 year later...
I have from time to time inverted the spray can drained all of the air from the can, then sit the
can upright on a hard surface and open the can with a chisel and put the content in a different
container.
Apply with your choice of material
