Bree,
It's not edging the liner (bottom strap) of the belt like I think it should. So now I'm playing with the thickness adjustment . There's nothing in the manual that covers the adjustment of that screw.
NRA Member
Certified Firearms Instructor
www.agcustomgunleather.com
Bree,
Do you have two blanks sewn together or are you edging a single blank? What is the total weight/thickness of the belt?
I ask because I have considered getting myself one of those if and when I get zapped at IBM and go into full time production. They seem to be great timesavers and promise consistent quality. So I am interested in any problems.
:red_bandana::red_bandana::red_bandana:
Ride Safe!
Bree
2003 Dyna Wide Glide
Memberships:
Iron Butt Association, Niagara Falls HOG, Wild Fire HOG
NRA, Niagara County Sportsman's Association
Bree,
They are great time savers - if they are adjusted properly. I would hate to continue to do this by hand. But for $600 they need to do the job. No one at Weaver can guide me (including Vernon).
But in their defense it could be cutting the belt & the liner correctly. They have to be one "with each other". Sometimes my straps are not straight. They have a slight curve in the middle (I have to work on that one) & I have no reason why. So in the glueing processs, I try to force everything in line & as it dries it moves. No way can you get a nice rounded edge.
If they are not married together & you do not sand them so they are - you will have a problem burnishing, regardless of the edging.
It's just a matter of craftmenship. I try to put out 10 units per day & at my level, it's just not going to happen.
NRA Member
Tom,
I can see why two ply on an EZ Edger can give you problems.
  • The EZ Edger just cuts the corners, like a Bissonnette edger.
    • Advantage = no reduction in strap width.
    • Disadvantage = in a two ply or straps cut to width unevenly it will skip spots.
    [*]The top and bottom blade sets follow your edges independently.
    • Advantage = its a nice design for single straps or uneven thickness (like heavy reins). If your thickness jumps drastically (like 10 oz to 14 oz) the blades will not cut any deeper.
    • Disadvantage = I would think soft lining leather can also be hard to edge. The strap is following the path of least resistance.
The NSB (and similar Italian edgers) uses shaped knives.
  • Advantage = Trims uneven edges (I don't care how ugly they are) to a smooth round edge. It can true up an uneven width, and much faster than pulling them by hand. Multiple ply straps are not a problem.
  • Disadvantage = It will reduce your strap width some. How much is adjustable with the guides. Since its a shaped knife, it will cut everything equally, so if the thickness changes drastically, you'll see a change in the radius.
Weaver used to sell the NSB in there catalog. I think they now only show the EZ Edger because the price is right for smaller shops. They use our NSB machines in their factory.
Edited by CampbellRandall
  • 4 years later...
So is that Weaver Edger $600? I can't get them to give me the time of day.
