Members whinewine Posted July 3, 2009 Author Members Report Posted July 3, 2009 Marlon: I sharpened it, but haven't stropped it yet & haven't compared it to my professionally sharpened knife. Right now, I'm in prep for a few shows & am busy with other things- like checking out a few new venues (found one today that may be fantastic for 2010). - this is the busiest time - did a few shows up till now- very poor so far- the 2 major shows we do, well, they occurred on the same date this year, AND, we were in Boston for a family function, so we blew off some good $$$. I'll let you know how the knife turns out. Thanks. russ Quote
Members Rawhide Posted July 4, 2009 Members Report Posted July 4, 2009 (edited) Marlon,Just be careful not to do anything to effect the temper...I know you already know that...but it's over a hundred years old.....it deserves a few age spots! I know you'll love it! Bob Hi Bob, Will the blasting ruin the temper? I certainly don't want to do that. So far I've slow wet grinded the bevel, then used my cardboard wheels to put an edge on, and hand polished with 800 grit/1200 grit/2000 grit/green rouge strop. I bought one of those portable blasters from Harbour freight and some 70 grit medium, I was going to try it out on some old metal to see how well I can control it first. I may just leave well enough alone. Any advise would be welcome. Thanks. By the way, did you sell your extras yet? If you decide to let one of those beard mauls go, let me be the first in line!!! Edited July 4, 2009 by Rawhide Quote Marlon
hidepounder Posted July 4, 2009 Report Posted July 4, 2009 Hi Bob,Will the blasting ruin the temper? I certainly don't want to do that. So far I've slow wet grinded the bevel, then used my cardboard wheels to put an edge on, and hand polished with 800 grit/1200 grit/2000 grit/green rouge strop. I bought one of those portable blasters from Harbour freight and some 70 grit medium, I was going to try it out on some old metal to see how well I can control it first. I may just leave well enough alone. Any advise would be welcome. Thanks. By the way, did you sell your extras yet? If you decide to let one of those beard mauls go, let me be the first in line!!! Marlon, I don't know if sand blasting or bead blasting would have any effect on temper or not....it doesn't seem like it....but the truth is I don't know and I would like to. Bob Quote
Contributing Member TwinOaks Posted July 4, 2009 Contributing Member Report Posted July 4, 2009 I don't see how sand/bead blasting it would affect the temper, unless s/b blasting REALLY heats up the steel. If anything, I'd suspect the airflow would cool the blade. The steel's temper shouldn't be affected by anything under about 300 degrees or so.( note: I've got an interest in knife making, but I'm not a metalurgist) Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
JohnD Posted July 4, 2009 Report Posted July 4, 2009 Marlon, I'd also be careful about sandblasting that blade for the fact that when you sandblast steel it has a tendency to flash rust very quickly. John Quote (rdb):God looked down at the world, and said "See, right there in Witchita, next to the railroad tracks, I didn't put enough dandelions".
Members steveh Posted July 4, 2009 Members Report Posted July 4, 2009 marlon, If that was my knife I would not bead blast it. That 70 grit will give the blade a texture, something you dont want. I would recommend soaking the blade in some kerosene , just the blade not the handle, overnight, and then give it a polish with some croacus cloth, this should help clean it up. in addition to to a keen edge, a high polish back from the edge of the blade helps the knife glide thru the leather. Steve Quote
Members Rawhide Posted July 4, 2009 Members Report Posted July 4, 2009 Thanks for all the suggestions, I kind of figured I'd do more damage than good. By the way Steve, where do I get croacus cloth? Thanks Quote Marlon
Members steveh Posted July 4, 2009 Members Report Posted July 4, 2009 Thanks for all the suggestions, I kind of figured I'd do more damage than good.By the way Steve, where do I get croacus cloth? Thanks Marlon, crocus is iron oxide cloth sheets , used for a fine finish on metal.You can use it wet or dry. Quote
Moderator Art Posted November 18, 2010 Moderator Report Posted November 18, 2010 MSC or McMaster Art Marlon, crocus is iron oxide cloth sheets , used for a fine finish on metal.You can use it wet or dry. Quote For heaven's sakes pilgrim, make yourself a strop!
gtwister09 Posted November 18, 2010 Report Posted November 18, 2010 (edited) Marlon, I have seen Crocus cloth listed between 1200 and 1500 as the grit. If you used your progression that you had listed then you worked through it. For a while you could get it at Woodcraft but I haven't seen it listed or in the stores for some time. The last bit I picked up it was cheaper on Amazon that what I could get it at MSC or McMaster's. Go figure! I haven't checked for a while. Regards, Ben Edited November 18, 2010 by gtwister09 Quote
