Members shaylajade Posted May 15, 2009 Members Report Posted May 15, 2009 (edited) For those of you who use Saddle Lac as your finish/sealer, what is the life expectancy/duration of the finish? It seems the be doing the trick now; it doesn't crack, it's amazingly water proof, doesn't smell bad etc, but I'm worried about putting on say a dog collar, having someone use the collar regularly and the Saddle Lac breaking down, allowing water in, color out etc. Does this make sense? Thanks for any input. I feel like we're ALMOST there! Edited May 15, 2009 by shaylajade Quote
Members jbird Posted May 15, 2009 Members Report Posted May 15, 2009 the stuff is very hardy if its used on saddles it can be used on most any thing nothing is that good you will have to refinish at some point I use it on belts every day its strong Josh Quote
Members shaylajade Posted May 16, 2009 Author Members Report Posted May 16, 2009 For those of you who use Saddle Lac as your finish/sealer, what is the life expectancy/duration of the finish? It seems the be doing the trick now; it doesn't crack, it's amazingly water proof, doesn't smell bad etc, but I'm worried about putting on say a dog collar, having someone use the collar regularly and the Saddle Lac breaking down, allowing water in, color out etc. Does this make sense? Thanks for any input. I feel like we're ALMOST there! Thanks Josh! I appreciate the feed back! Quote
hidepounder Posted May 16, 2009 Report Posted May 16, 2009 For those of you who use Saddle Lac as your finish/sealer, what is the life expectancy/duration of the finish? It seems the be doing the trick now; it doesn't crack, it's amazingly water proof, doesn't smell bad etc, but I'm worried about putting on say a dog collar, having someone use the collar regularly and the Saddle Lac breaking down, allowing water in, color out etc. Does this make sense? Thanks for any input. I feel like we're ALMOST there! I don't use Saddle Lac, but I have in the past. I'm with Josh, I think it's a pretty good sealer, and anything that you choose will have to be rejuvinated. Bob Quote
Members kevinhopkins Posted May 16, 2009 Members Report Posted May 16, 2009 Hi... We manufactured a number of wallets and belts for years using Neat lac spray as a final finish. We switched to saddle lac, and really couldn't tell much difference. We just put down a light coat first, and another on top of it, and those wallets and belts are still walking into our store after many years of service. Kevin Hopkins Quote
