Members Shorts Posted June 27, 2009 Members Report Posted June 27, 2009 Is it possible to make a kydex clip that you can attach a belt loop to instead of using the regular clips? I've got a holster coming in soon and am thinking about trying to make one to convert my holster to tuckable while still being able to use the leather loops which I prefer for attachment purposes. Seems like it would be pretty easy. Possible. I've toyed with the idea myself but haven't got around to building anything. Quote
Members woolfe Posted June 27, 2009 Author Members Report Posted June 27, 2009 Is it possible to make a kydex clip that you can attach a belt loop to instead of using the regular clips? I've got a holster coming in soon and am thinking about trying to make one to convert my holster to tuckable while still being able to use the leather loops which I prefer for attachment purposes. Seems like it would be pretty easy. That would work and it would be pretty easy to do. I originally wanted to do something similar, maybe the same thing you are talking about. Make a "U" shape out of a Kydex strip and just attach your belt loop to one end of it. You can get Kydex 12" x 12" squares from http://www.knifekits.com/vcom/index.php?cPath=41_54_136 for less than 10 bucks and all you would need is a way to cut off 2 strips, drill holes, and a Bic lighter to heat the kydex where you want to bend it. I use a table saw to cut mine and a drill press to drill the holes, you could do both with a dremel tool. Quote http://www.woolfegunleather.com/
