Ed, I'm certainly interested in the results!
I do have a teensy recomendation for this.....portion into sealable containers early in the experiment. If this is similar to the stuff I used before (not on leather), it dries pretty quickly and you can get glue boogers inside the can that'll drop into the mix and make a mess when you try to spread it.
I get those "boogers" even with Tanner's Bond. It's not too bad, but occasionally I have to pick them out. My big criterion is that it dries clear.
ed
  • Replies 42
  • Created
  • Last Reply
Top Posters In This Topic
Ed, that kind of adhesive usually dries to a yellow, try a pint tub first.
Ed
I had a look at the US Home Depot and Lowes websites, and I can't see an equivalent product . . . but I'm sure there must be one somewhere!
There seems to be a difference in definition in the US between PVA and latex. I think PVA may be called 'synthetic latex' on your side of the pond - but you're right - the Wickes product is builders' adhesive.
Terry
When everyone is somebody, then no one's anybody
Terry,
Thanks for checking into this. I should be able to get to one of these stores in the next few days to try out this PVA.
Ed
Ed
Terry
Ed,
Your link goes to the p/n 3300-1 but, the p/n 2057-1 says it dries clear. The 3300 does not say one way or the other. Both of these also come in quart size so we can try them out for less than 4 bucks each. I'll be in homedepot today and will pick them up (if in stock).
Regis
God, Family, and Country (although liberals are attempting to destroy these in the USA)
Isn't woodworker's glue the same kind of glue?
I was a bit quick in placing the link. The 2057 does seem the best bet.
Ed
Ed,
Regis
Wood glue, if it dries clear and doesn't take too long to set, would work well and seems to be a little less expensive than Tanners Bond.
Another thing I noticed with the wood glue is that the set time is about an hour and the curing time 24 hours, about the same as with Tanners Bond. The 2057 has an open time of about 45 minutes, which may make it more similar to TB than are the other building glues.
ed
Edited by esantoro
