Members TomBanwell Posted June 29, 2009 Members Report Posted June 29, 2009 I just bought a used Boss, and it looks pretty good like it has little wear. The presser foot was not moving smoothly, and now its stuck in the up position. The cable is moving at the handle end, so I'm assuming it isn't attached at the foot end. Can I safely remove the front cover to look at it without a problem? I don't want any springs to go aflying. Thanks. Quote
Members celticleather Posted June 29, 2009 Members Report Posted June 29, 2009 Tom Not sure what's wrong here, but I would recommend fully unscrewing the presser foot pressure screw before you investigate. The presser foot is held down by a pretty hefty spring, and if it suddenly released with a finger in the way, things could get very painful and messy! Terry Quote When everyone is somebody, then no one's anybody
Members whinewine Posted June 29, 2009 Members Report Posted June 29, 2009 I just bought a used Boss, and it looks pretty good like it has little wear. The presser foot was not moving smoothly, and now its stuck in the up position. The cable is moving at the handle end, so I'm assuming it isn't attached at the foot end. Can I safely remove the front cover to look at it without a problem? I don't want any springs to go aflying. Thanks. Call Tippmann first! They're very good about helping. russ Quote
Members Randy Cornelius Posted June 29, 2009 Members Report Posted June 29, 2009 Sounds like your cable is broke. Call Tipman. Quote Randy Cornelius Cornelius Saddlery LaCygne, Kansas Randy & Riley Cornelius Ride Hard, Shoot Fast and Always Tell the Truth...
Members TomBanwell Posted June 29, 2009 Author Members Report Posted June 29, 2009 Thanks, I called them and talked to Tom. Since the foot was stuck it sounded to him like something was "gummed up". I opened the front cover and pried with a screwdriver and the foot slammed down. Then generously oiled everything relating to the foot. Working good now. Quote
Members celticleather Posted June 29, 2009 Members Report Posted June 29, 2009 . . . the foot slammed down. That's the dangerous part! Quote When everyone is somebody, then no one's anybody
