Any machinists interested in reproducing solid brass and solid nickel briefcase locks?
Ed,
It's actually quite easy but digital readouts are a great feature to have.
When I get around to replacing gear it will be one of the larger mini-mills with a DRO and CNC kit added to it rather than the Sherlines. Work envelopes are larger and they are more heavy duty and are less expensive.
On the other side if you don't need the size then the Sherlines are great. They also are higher quality equipment out of the box with CNC ready kits as well as ready made machining kits to add to the mill and/or lathe.
Regards,
Ben
