Members cdthayer Posted August 28, 2009 Members Report Posted August 28, 2009 ...Yours looks like it will be a great restoration. The 70 looks like it is in close to the same shape as mine was when I started. Good luck and if you need anything, let me know. Beener, How are you coming with getting your machine adjusted to sew? I finished my clean-up on the 28k70, and have it sewing (at least by hand crank). I never will get it to look as good as your 29k58, but it's useable now. The Stitch Regulator and Check Lever are pretty well worn, and the Bobbin Winder is pretty sloppy, but everything else is in pretty good shape. I have a Stitch Regulator coming for it, and I dressed the thread notch down in the Check Lever eye so thicker thread won't snag. As a side note, I hadn't noticed that the Needle Bar Driving Lever (top arm) on mine was from an earlier model, probably a 29-4, and it doesn't have the adjustable Check Lever feature that is on the later models. It seems to sew ok with this arrangement. Nice thing about these old machines; parts will interchange on them. CD Quote "I sew, I sew, so it's off to work I go....." My sewing machines:Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
