MarkB Posted August 7, 2009 Report Posted August 7, 2009 I am using stuff called milk board that you can get at Home Depot. I is like that stuff Bobby is talking about. It come in 4x8 sheets and you can cut it with a good knife or good set of shears. It is flexable and makes a nice pattern that does not wear on the edges. I had never thought to use it for a stiffener, learn something here every day. Thanks Bob Mark Quote Visit My Website To succeed you must try, Not trying your sure to fail.
hidepounder Posted August 7, 2009 Report Posted August 7, 2009 I use Bontex. I use it here and there for bag stiffener ( I buy it at Tandy, They sell it as "bag stiffener") I have been using it since I started in leather work. There are some draw backs though if you are not careful while tracing you can distor the pattern over time. I personaly am going to look up some of Bobs styrene it wound like the winning ticket.One question Bob what do you cut it with Just shears? Tim I use a knife, Tim. If you score it deep it breaks cleanly. Quote
TimKleffner Posted August 7, 2009 Report Posted August 7, 2009 Thanks Bob , Good info. I'm going down town and will stop by the glass/plastics shop. Tim Quote It's hard to fail, but worse never to have tried to succeed.Theodore Roosevelt
JohnBarton Posted August 8, 2009 Report Posted August 8, 2009 Thanks Bob , Good info. I'm going down town and will stop by the glass/plastics shop. Tim We use thin white cardboard, similar to posterboard but cheaper. This is what we use for all of our patterns because it can be written on folded, taped, and easily duplicated. Cardboard can be folded along the centerlines to insure that it is accurate and symetrical. This ability to fold it also means that you can often make other parts when you need just a section of a pattern for some reason, i.e. just the corner of that pattern for this new pocket. We generally make the patterns on the computer and use the laser to cut them. When we make a pattern by hand we will duplicate on the computer so that it is always there for us in the event that we lose or destroy a paper pattern. Also by being on the computer we can modify and make an new pattern in very little time. Over the years I have tried many substances for patterns including some of the ones mentioned above and I always come back to the cardboard due to it's flexibility. When the laser is down, out come the patterns and we continue making the parts without skipping a beat with the exception of the very complicated parts that have a lot of intricate curves. Then we just take more time and use the exacto knife. I am not your idol Phillip? I am hurt. ;-) Quote Support Quality. We are all humans. Buy the best no matter where it's made. That way everyone lives in harmony. Nature knows no flags.
Members filluptieu Posted August 8, 2009 Author Members Report Posted August 8, 2009 I am not your idol Phillip? I am hurt. ;-) Did I not mention you? crap! Mr Barton you are also my idol. but honestly you are the person i go to for creativity in different designs. Thanks for the input. when you get the patterns laser printed can this be done at a place like kinkos? or does it require a special machine Quote
Members tonyc1 Posted August 8, 2009 Members Report Posted August 8, 2009 I get remnants of lino which is very cheap and cuts like butter! Edges don't fray either. Tony. Quote
JohnBarton Posted August 8, 2009 Report Posted August 8, 2009 Did I not mention you? crap! Mr Barton you are also my idol. but honestly you are the person i go to for creativity in different designs. Thanks for the input. when you get the patterns laser printed can this be done at a place like kinkos? or does it require a special machine LOL. It's ok, if any of us can have half the success Jack has had in both making consistently fantastic cases and making friends throughout the world then we will have a wonderful life. Please just call me John. When I said that we "print" it with the laser I meant that we cut the pattern out using cardboard using out laser cutter. Before we had the laser cutter we would literally print the pattern on paper and transfer it to cardboard. You need to set your printer to print a full size and if your program has a way to tile the printout then do that. You can test your printer settings by making a rectangle and then printing the rectangle to insure that it comes out exactly at the size you created it to be. You can also have places like Kinkos print out your patterns in full size - I don't know if they can print on posterboard. Any sign shop can easily do your patterns and cut them with a plotter or also laser cut them. But honestly, you don't need all that. Right now you need to focus on keeping your patterns simple and learning how to make them by hand. There have been a lot of good suggestions here on materials to use for your patterns. Like I said I prefer the cardboard. Another thing I would suggest is to use the printer to test your patterns. I regularly build paper mockups where I will print the patterns and use scotch tape to mock up the part. This really helps to work out the kinks before you start cutting up a bunch of leather. Quote Support Quality. We are all humans. Buy the best no matter where it's made. That way everyone lives in harmony. Nature knows no flags.
JohnBarton Posted August 8, 2009 Report Posted August 8, 2009 Also I want to add that we need to distinguish between a pattern and a template. A pattern is the blue print for a part. Depending on what it's made of it can also act as a template. A template is something that I use to cut parts or set the proper spacing. We make a lot of templates out of wood and heavy plastic sheeting and use those to cut parts without having to mark the leather first. Patterns are generally used for marking the material prior to cutting it. Using a template you can just cut the material without marking it first. One of the factories I work with uses some metal templates with handles. They lay it down on the leather and run the razor around it and cut a perfect part every time. Beyond that they always have cutting dies for cutting parts on the clicker press. I have seen them use the cutting dies as a manual template for both marking and cutting. Quote Support Quality. We are all humans. Buy the best no matter where it's made. That way everyone lives in harmony. Nature knows no flags.
