Hmmmm...... just call me frugal and lazy! :) I use a clip board and lounge on the couch while I braid. No sore shoulders for me! I'll try to post this picture of my granddaughter. I was teaching her how to braid (she did really well!) and it shows the clip board in use! I have been able to braid bosals, reins, everything on the clip board and it holds the piece straight so I don't get the twists in the braiding. Here goes ... hope this works!
LOL! Since that worked, I'll describe it a little further. You don't have to prop the clip board against anything but your lap/stomach. You can see by the picture that my granddaughter is slouched in a chair on the back porch. Totally relaxed! The harder you pull, the more it wedges in against the resistance. When it gets so long that it is uncomfortable to braid, you just press the clip and move it up! That simple. I plaited a 60" piece tonight while watching NASCAR and then moved onto some other braiding. But I don't have to be detached from my family to braid, it is portable and CHEAP! :)
Love and Light,
Maeve
I sit in a very comfortable chair (that I shopped for, particularly as to leg length and height) with armrests. My braiding is clamped to what is actually a quilt rack. I can easily move this back from me the longer the braid gets. It moves close enough to the chair that I can start the braid, then as it grows longer I push it from me. Occasionally I am doing a very long braid and in that case it will go up over the top of the rack, and wind through the other parts of the rack.
This is very important to me as I have carpal tunnel: I make CERTAIN that my hands never bend inwards. I keep my wrists STRAIGHT as I braid, or bent outwards - NEVER inwards.
I also make sure I can braid with my elbows supported and without slumping over. There are times I will sit forward and support my elbows on my knees, and lean forward a bit, just for a change in position.
I braid pretty much all day long, starting about 8 AM and sometimes not stopping until 1 or 2 AM. Usually though I stop about 7 PM for a couple of hours, then braid from about 9 PM to 11PM. That said, I take a break for 10 - 15 minutes every two hours or so which is why I am sometimes on here every two hours... I'm just taking a break!
During Christmas rush I get pretty sore. My arms sometimes feel like they will fall off... I just try and take those breaks, getting up and stretching, and moving to slightly different positions.
They say princes learn no art truly, but the art of horsemanship. The reason is, the brave beast is no flatterer. He will throw a prince as soon as his groom. - Ben Jonson
http://www.beautiful-horses.com
  • 1 month later...
I have actually spent a lot of time working on finger and arm exercises for other hobbies.
So heres a huge list of them for you to use.
Because we as braiders are usually pulling strongly against thedirection of the fingers, we need to increase our resistance to lateralmovements.
More recently I keep my fingers strong and arms used to air work by twirling a steel bar, recently leather wrapped. It's about one foot long and half inch wide or so and weighs probably 400 grams. I twirl it around all the fingers underneath my hand then lifting the hand the other way reverse the direction, then I spin it around the thumb and spin the hand back over to restart the underneath cycle. It's much harder with the left hand when starting. I used to use two two foot wooden bars wrapped in leather, and work both sides at the same time but they are currently in storage...
Another exercise is rocking the bar side to side between two fingers, holding the hand thumb up and pinky down... Very painful if over done. Work between all the fingers.
More for the fingers, find yourself two marble balls about three inches wide, and rotate these the smaller exercise balls, work in both directions for five minutes each.
Keeping the palm as straight as possible, reach the tip of each finger one at a time back as far as possible without any other finger moving, Hold for 3 sets of teen seconds each then move on. Both hands now...
For the wrists, tie a filled two-five litre bottle to a staff securely with three feet of string, grab either end of the rod and twist, twist, twist, up one side then slowly down and finally repeat until pulpy arms syndrome.
For arms in general throwing and spinning once a hammer in the following order helps the arms and shoulders remain supple and loose.
Left to right
right to right
right to left
left to left
repeat
DO you make tamales? If not learn to work your forearms and wrists in doing so.
Tamale as quickly as possibly 50 metres of 2mm lace, much wider and it gets unmanagable.
I bet you can't get to fifty without stopping or slowing down.
Hold your arms straight out in front of you, and do mexican waves with the fingers without moving anything but your fingers. It won't look like a mexican wave, but doing this for five minutes sure makes you feel it. And this won't make sense to read but do the waves slowly but strongly.
Before any work gets done, warm with some sort of exercise each muscle to be used.
Also card tricks, balisongs, pen spinning, zippo tricks, contact juggling etc are all good exercises for finger dexterity.
One last fore arm exercise, screw 2 six inch nails into a hard wood block with a manual screw driver. I would say use the left to unscrew it but I never did.
As for the back...Tai chi
Door side and a vice...or broken swing (don't ask)
Hope these work for you, they have worked for me for over ten years.
Doing the right thing is bleeding for the cause.
Website
Facebook
Thanks for the ideas 8th! I am going to try some of those exercises. I do yoga and have been told repeatedly that I need to start Tai Chi also, no time like the present.
The one really simple thing that I have incorporated into my routine is the water bath. Alternating between hot and cold water 2 minutes each for 3 sets with palms down, fingers spread. It really helps improve the circulation.
Keep Braiding,
Heather
www.opagonfarm.com
The water thing I have never heard seperated from the full shower version which helps boost the immne system and skin in general.
Thanks for sharing.
Website
Facebook
