Members DougVL Posted September 27, 2009 Members Report Posted September 27, 2009 Looking for help repairing my new-to-me old Singer 112W139 machine. I tried to find out just how old it is, but Singer says their data from the period when my serial number W1324293 was made was lost during or after WW II. I recently got a Singer 112W139 and I need some help with it. The stitch length adjustment doesn't work. The machine sews pretty well but only at the longest stitch length. I have been examining the stitch length adjustment mechanism but I don't understand how it works. I have seen the mechanisms on other machines - home sewing models and my Mitsubishi LU2-400. I understand those, but they're all different than the 111W series machines with the stitch length adjustment control at the center of the machine drive pulley and working inside the machine's upper arm shaft. On my machine, the adjuster won't turn, which would move it in and out because of the thread on the pulley end of the arm shaft. I have found that the FEED DRIVING ECCENTRIC REGULATING SCREW (part number 200429) is broken and about half of it is missing. The lower, rounded-end part that would engage the point on the end of the FEED REGULATING SPINDLE (part number 224122) is gone. Or maybe still stuck inside the FEED DRIVING ECCENTRIC REGULATING BRACKET (part number 237521). I would really like to find a diagram that shows the machine's feed length components together in their working relationship. I have a Mitsubishi LU2-4410 manual and it has a sort of cutaway drawing like that, and I've seen feed mechanism drawings in the couple of sewing machine repair books I've been able to read. Page 18 of the 111W & 112w manuals have an X-ray view of the Feed Driving Eccentric Regulating Bracket and Shaft which shows the the adjusting screw, and the spring and plunger on the opposite side of the shaft. But it doesn't show what the shaft is adjusting or how adjusting it affects the stroke of the stitch length mechanism. So, if anyone can help me find some information to help troubleshoot and repair my machine, I'll be very grateful! And of course I need to find a few parts, even a new arm shaft (p/n 240102) because the stitch length control thread on the pulley end has also been damaged, presumably by someone's attempts to turn the adjustment. Although replacing that shaft would be very difficult - maybe I'll have to live with limited functionality of the stitch length control if I can even get the adjustment mechanism to work at all. BTW, I'd also like to find out when it was made. Its serial number is W1324293, but the Singer dating site says the records for this range of serial numbers was lost or destroyed around the time of WW II. Quote DougVL
CowboyBob Posted September 27, 2009 Report Posted September 27, 2009 I'll try to explain it,the feed cam @ the top pivots towards & away from the shaft as you turn the knob in & out because the end of the shaft is tapered to a point,so since the threads are srtipped you can just push the stitch length adjuster in all the way & then go in through the top cover & there should be a small screw to take out & a longer one that you can turn in or out to adj. the stitch length.The short screw locks the longer one from turning when sewing. I can get a new top shaft & most other parts if needed. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members DougVL Posted September 27, 2009 Author Members Report Posted September 27, 2009 I'll try to explain it,the feed cam @ the top pivots towards & away from the shaft as you turn the knob in & out because the end of the shaft is tapered to a point,so since the threads are srtipped you can just push the stitch length adjuster in all the way & then go in through the top cover & there should be a small screw to take out & a longer one that you can turn in or out to adj. the stitch length.The short screw locks the longer one from turning when sewing. I can get a new top shaft & most other parts if needed. Bob - Thanks for the info and the quick response. The longer adjusting screw you mentioned is the one that's broken. The rounded tip end of it is missing, and may be somewhere inside the shaft. With the long & short adjustment screws removed, by poking a small screwdriver in I can feel the pointed end of the stitch length adjustment spindle, although the hole is too deep and narrow to actually see the point of the spindle down there. The thread on the end of the shaft is broken off in a couple of spots at the very end of the shaft, apparently from someone trying very hard to turn the stitch adjustment. I still need to try turning the machine up on end with the stitch length adjustment spindle removed to see if the broken part of the screw falls out, but it may be jammed in tightly. For my primary intended use, full max length stitch is about all I'd need and so I don't really have to repair it. But I'd really like to be able to, just because repairing things has been my job and hobby for a long time. Doug Quote DougVL
CowboyBob Posted September 28, 2009 Report Posted September 28, 2009 Doug, You could get a piece of roundstock long enough to go past the hole & then you won't need to worry about that broken off piece of screw just tighten on the flat spot of the round piece you put in there. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members DougVL Posted September 28, 2009 Author Members Report Posted September 28, 2009 Doug, You could get a piece of roundstock long enough to go past the hole & then you won't need to worry about that broken off piece of screw just tighten on the flat spot of the round piece you put in there. Put the round stock into the end of the arm shaft? Or into the setscrew hole, where the broken screw goes? The first would be about 6 inches of 1/4 inch diameter, the second about 1 inch of 1/8 inch diameter. I did tip the machine up on end and get the piece of broken off screw to come out. It's about the same length as the the other part, with the screw head and a few threads and a little of the smaller diameter threadless tip. Doug Quote DougVL
CowboyBob Posted September 29, 2009 Report Posted September 29, 2009 Doug, Pull the knob & stitch adjuster shaft out & put it in there, yes,around 6" long.We put a small bend in them (the shaft) so they don't slide out. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members DougVL Posted October 2, 2009 Author Members Report Posted October 2, 2009 Doug, Pull the knob & stitch adjuster shaft out & put it in there, yes,around 6" long.We put a small bend in them (the shaft) so they don't slide out. Thanks! Now I understand. It did seem like the pointed end of the adjuster shaft must be doing the work, but I had thought that it might be the side of the taper, working as a cam. But this means that the taper was for the tip of the adjusting screw to limit the movement of the adjuster shaft inwards. Quote DougVL
Members DougVL Posted November 27, 2009 Author Members Report Posted November 27, 2009 Thanks! Now I understand. It did seem like the pointed end of the adjuster shaft must be doing the work, but I had thought that it might be the side of the taper, working as a cam. But this means that the taper was for the tip of the adjusting screw to limit the movement of the adjuster shaft inwards. FOLLOWUP POSTING: that didn't work. One of the interior parts is broken off and the shaft cannot adjust the stitch. By loosening a clamp bolt on a feed length bracket, I can adjust it, and then tighten the bolt to hold that setting. Doug Quote DougVL
Cobra Steve Posted November 27, 2009 Report Posted November 27, 2009 FOLLOWUP POSTING: that didn't work. One of the interior parts is broken off and the shaft cannot adjust the stitch. By loosening a clamp bolt on a feed length bracket, I can adjust it, and then tighten the bolt to hold that setting. Doug Hi Doug, just a follow up to what Bob said... you might need to oil and spray some penetrant into the mechanism. I have seen many machines that the stitch length mechanism is frozen and needs to be broken free. Try this as well as what Bob said. Thanks, Steve Quote Thank You Steve Tayrien Leather Machine Co., Inc. 2141 E. Philadelphia St. Unit "U" Ontario, California 91761 1-866-962-9880 http://www.leathermachineco.com [email protected]
CowboyBob Posted November 28, 2009 Report Posted November 28, 2009 Doug, Here's a internal view of the stitch length adjuster ,the screw @ 9:00 is where the part slides back & forth when you adj the stitch either by turn the knob DD in & out or you can takeout screw BB & turn CC in f/longer & out f/shorter. Does your screw CC have the pin on the end of it?Also is DD all the way in when trying to adj? Let me know if you have anymore questions. Thx, Bob Kovar Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
