Members TexasLady Posted June 27, 2011 Members Report Posted June 27, 2011 6/26/11 Hi Crystal, Like everybody else, I enjoyed reading the key fob tutorial. But like most people on this Thread, I don't see a link to any pattern or photos. Since the only leather key fobs I've seen are those 'one-sided' ones at Tandy, I can only see the key fob of the tutorial in my imagination. Perhaps the links got lost when this tutorial got pinned? Please help. I'm writing you because I can see the long string of requests for the pattern or photos, and yet, no answer. - TexasLady Thanks for writing up the tutorial and for providing a pattern, Storm! I've pinned this so folks will be able to find it. Crystal Quote
Contributing Member Crystal Posted June 28, 2011 Contributing Member Report Posted June 28, 2011 6/26/11 Hi Crystal, Like everybody else, I enjoyed reading the key fob tutorial. But like most people on this Thread, I don't see a link to any pattern or photos. Since the only leather key fobs I've seen are those 'one-sided' ones at Tandy, I can only see the key fob of the tutorial in my imagination. Perhaps the links got lost when this tutorial got pinned? Please help. I'm writing you because I can see the long string of requests for the pattern or photos, and yet, no answer. - TexasLady Thanks for the heads up, Texas Lady. The member that started this thread removed the pictures, so there is no way to recover them. I am going to "un-pin" this since there are no pictures available. Crystal Quote Black Dog Custom Leather
Members TexasLady Posted June 28, 2011 Members Report Posted June 28, 2011 6/28/11 Thanks for the response, Crystal. Even the tutorial alone is worth reading,... just the frustration, you know, of not being able to see what he's talking about. Any chance that Storm would re-share the pattern and photos? - TexasLady Thanks for the heads up, Texas Lady. The member that started this thread removed the pictures, so there is no way to recover them. I am going to "un-pin" this since there are no pictures available. Crystal Quote
gtwister09 Posted June 29, 2011 Report Posted June 29, 2011 (edited) As I have said many times before...this is the reason for your photos to be loaded onto Leatherworker so that shared photos and a good tutorial are not ruined when the pictures are removed.... A PICTURE IS WORTH A THOUSAND WORDS. ALL. Please consider loading pictures onto this forum rather than linking them to a photo site so that this doesn't happen. Regards, Ben Edited June 29, 2011 by gtwister09 Quote
Members faithskins Posted October 17, 2011 Members Report Posted October 17, 2011 I couldn't see either the pattern or the picture of the finished product. I don't understand why, but I sure would like to see them. Instructions On How To Go About Making It. Some people have asked and so here are some instructions to help anyone needing same. First cut out the fob carefully after tracing it to the leather. Punch your hole for the concho I will then die using and all in one from ecoflo. Front first and then the back in the center where there will be no glue. I put the key ring on and attach the concho. Then I fold over the two halves without gluing the and while holding them in place I mark both pieces, top and bottom on both s with a pencil. You are locating the upper most part of the gluing area. Now open it up and on both sides draw a curved pencil line to each of the two points on both side. This curved line is the upper limit of you gluing. I then burnish the inside between the two circles of the fob where the keyring goes. Take the contact cement and carefully apply to both sides. Let it dry until tacky. Once tacky carefully fold over the two sides and join them together slowly and as closely as possible. Use a shoemakers hammer to tamp on the surrounding edges. Of course it is very likely there will be variations and a little unevenness. This might happen even if you did have them die cut. This is when I bring out my Dremel tools and use a drum sander attachment. Then by hand I get rid of the imperfection. The subtle sanding also has a way of prepping the edge for finishing. I use a groover and then hand sew the two sides together. The I use a bone folder on the water moistened edge and smooth it down. I come back and use the all in one on the edge and let it dry. The finally I finished the edge to a glossy finish. Quote
LNLeather Posted February 14, 2014 Report Posted February 14, 2014 You can find info and a pattern here http://www.kingsmere...com/page74.html Quote ~Cheryl There are many things in life that will catch your eye, but only a few will catch your heart... pursue those...
Members WyomingSlick Posted February 15, 2014 Members Report Posted February 15, 2014 Here's a useful innovation for a sewn key fob. Cut an oval slot near the key ring end on one side, and only glue and sew the outside edge of the fob, thereby creating a useful little pocket. That little pocket is a dandy place to keep and always have with you one of those SD memory chips used in cameras, computers, etc to store data. It could also be used to carry a few quarters, or perhaps some folded currency. Quote (John 8:32) And ye shall know the truth, and the truth shall make you free. (KJV) And the truth is that religion is nothing more than the lame attempt by largely ignorant people to bring sense and order to a world that was beyond their comprehension. Once you see religion for the delusional and superstitious artifact it is............... you will be free !
