Members TXAG Posted August 10, 2014 Members Report Posted August 10, 2014 With the Press-n-Snaps I've found you can sometimes get "loose sets" with the posts'n'studs - where the post part curls enough to lock the stud into place but not tightly enough to keep it from spinning like a pinwheel. This happens when someone doesn't know the correct way to use the press-n-snap. To install them the right way, you begin setting it with the screw adjusted so you just have slight resistance. Then, while keeping tension on the pliers part, adjust the screw so the handles open up a bit. Squeeze it tight again. Repeat until the snap is good and tight. I do it this way with the press-n-snap and none of my snaps spin around at all. They're all set very well and tight. Quote
