As promised here is how I build and install a fail proof system for keeping my bicycle bags closed.
(Move Left to Right while looking at the photos.)
1 Bag with long slot cut in flap and strap lined up with it and about 1 inch longer than the flap. On this bag the strap and loops for holding the hooks are one.
2 Tools and materials. On this bag I'm using Al welding rod. You can use brass brazing rod, heavy copper wire or even nails.
3 A finished keep ready for installing. This is a jig I made out of 3/4 inch angle iron to bend the keep. NOTE: Al will crack if bent to sharply. It is soft enough to bend with your fingers and then gently tap with a hammer.
4 Fold the flap down and use a piece of the metal to mark where the holes need to be.
5 Because I don't have a satisfactory way to back the leather to punch it, I simply drill it. (I do finish the hole with a touch of edge coat)
6 Keeps pushed into the holes in the bag.
(Imagination time! Next four photo are not an actual installation - because I can't get a camera into the bag!)
7 Keep pushed all the way through the bag and a spacer block set between the prongs.
8 Prongs folded over and trimmed. (This does take work on brass and steel! Of course if you able to do it in a larger space . . .)
9 A leather patch is glued over the keep to prevent it from being pushed into the bag. I've use white, contact and Super with success.
10/11 I use a spring clamp and some medium dense foam to hold the patch in place.
12 Bag's ready for some finish touch up and onto the back of a Brooks Saddle.
That's it. Simple, inexpensive, functional and if needed, easy to repair along the road.
WesTexas
Chuck
Thank you so much for sharing, I'll be printing and keeping these instructions. I hope to have a set of bags to share in the future featuring your slick closures.
:You_Rock_Emoticon:
cowgirlrae & Glen Moulton
  • Ambassador
A very useful item.........Thank you so much for posting.
Luke
