gtwister09 Posted December 3, 2009 Report Posted December 3, 2009 Yes to the brown mouthwash... On a side note I had someone share with me the other day that they used this to keep something cased for 2 weeks with no mold or marking of the leather. I have to agree with Bruce on the quick casing penetrating more quickly with Procarve. I also agree with Bob's comments on the stropping and tough/hard leathers. Regards, Ben Quote
Members oldtimer Posted December 3, 2009 Members Report Posted December 3, 2009 is it tha bottle or the content that is brown? Quote "The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
hidepounder Posted December 3, 2009 Report Posted December 3, 2009 I tried the ProCarve and just didn't see where it was helping me. I don't think it held the moisture in the leather any longer than water with Joy dish soap added. While I'm not quite as excited about the Lexol solution as some others are, I do like it and I have to agree with Bruce that my leather stays moist longer....longer than Pro Carve and longer than plain water. I can't help but think that's the Lexol holding moisture in the leather. I'm not sure that if you are wetting your leather and going right to work that you will realize as much benefit from the casing solution, however it certainly will not hurt anything at all. You might achieve an increase in burnish color but probably not as much eaze in cutting as the leather will not contain the same amount of moisture as cased leather will. Bobby Quote
RandyScott Posted December 3, 2009 Report Posted December 3, 2009 is it tha bottle or the content that is brown? Oldtimer, remember way back.. way back before there were all these orange and mint flavored (blue or green) Listerine's? The 'Original' Listerine is the one the formula was based on. In my part of the world there is a grocery store chain that carries Listerine and their house brand. The formulation is almost identical, it works just as well and is a little easier on the wallet also. And to specifically answer your question, I believe the bottle is clear and the contents are brown. I will be at the grocery store in the morning and check it out. I will edit this post if a correction is needed. Quote Complacency Kills
TimKleffner Posted December 4, 2009 Report Posted December 4, 2009 Hi Ya'll Someone needs to register the recipe with the patent office. There's money to be made. Thanks for the info. I'm looking hard at this recipe, I've got a problem with black spots [mold]. Thanks for the help Happy tooling Tim Quote It's hard to fail, but worse never to have tried to succeed.Theodore Roosevelt
Members oldtimer Posted December 4, 2009 Members Report Posted December 4, 2009 Oldtimer, remember way back.. way back before there were all these orange and mint flavored (blue or green) Listerine's? The 'Original' Listerine is the one the formula was based on. In my part of the world there is a grocery store chain that carries Listerine and their house brand. The formulation is almost identical, it works just as well and is a little easier on the wallet also. And to specifically answer your question, I believe the bottle is clear and the contents are brown. I will be at the grocery store in the morning and check it out. I will edit this post if a correction is needed. Thank´s for the info. On this side of the globe Listerine is a green liquid, so I got a bit puzzled. / Knut Quote "The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
RandyScott Posted December 4, 2009 Report Posted December 4, 2009 Thank´s for the info. On this side of the globe Listerine is a green liquid, so I got a bit puzzled. / Knut Oldtimer, My bad... I was in a hurry as the wife was calling me to the dinner table and I did not check your location. Hmmm, if the version of Listerine marketed on your side of the pond is the same as ours, it really isn't a deep dark green. Get a small bottle of the Listerine, a small bottle of the Johnson & Johson No More Tears Baby Shampoo (if sold over there or any shampoo for babies that does not burn the eyes) and do a test. The Lexol Conditioner emulsifies, i.e., turns the liquid a whitish creamy color. The Listerine is only a tablespoon as per the formula posted above. I doubt the green will change the color of the liquid or the leather. Test first on scrap. The stuff keeps forever. I have about a pint left from a quart I made over a year ago and it is still good. It separates (stratifies) a little but a good shake of the bottle and it is ready to go. Randy Quote Complacency Kills
Members oldtimer Posted December 5, 2009 Members Report Posted December 5, 2009 Thank´s Randy ! Will make up a bottle of the mixture and give it a try! / knut Quote "The gun fight at the O.K. corral was actually started by two saddlemakers sitting around a bottle of whiskey talking about saddle fitting"...
BearMan Posted December 8, 2009 Report Posted December 8, 2009 Hi Everybody, Looks like I'm getting in late to this,,, but I thought I'd add in my formula. It's similar in a lot of ways. I've been using this formula for about 30 years now, & it works wonders. Basically it's: 4 Tablespoons of Lexol,,, 3 Tablespoons of Glycerin, 2 Tablespoons of Brown Listerine, about 40 drops of Dawn, or Joy , Mixed in 7 cups of warm Distilled water. Living in areas where Mold is a problem, the Listerine really seems to help. I either submerge the leather for a few seconds, until the bigger bubbles stop,,, or on thinner leather I spray it on. After the leather has come back to almost "tooling color", I put the leather under a sheet of heavy glass. I've has pieces under glass like this for over 2 weeks, & it comes out cased very nicely. I hope this helps somebody. It works for me... Ed the"BearMan" Quote Ed the"BearMan" polarb1717@aol.com Beary: BearMauls@yahoo.com http://tinyurl.com/BearMauls "The Best tooling mauls available today!"
