Butch Report post Posted November 25, 2009 Here's a couple of gun racks that I made recently. Thanks for looking. Butch Quote Share this post Link to post Share on other sites
terrahyd Report post Posted November 25, 2009 Man that is realy nice work ....DOC..... Quote Share this post Link to post Share on other sites
sdkid Report post Posted November 26, 2009 Very nice. I want to try a set of those someday. Quote Share this post Link to post Share on other sites
Storm Report post Posted November 26, 2009 Very nicely done! You took a lot of time and care in that one. Storm Quote Share this post Link to post Share on other sites
Butch Report post Posted November 26, 2009 Thanks everyone. These went to my wife's cousin. He wanted 1 that would hold 4 guns but I didn't think the weight of 4 guns would be a good idea. Thanks, Butch Quote Share this post Link to post Share on other sites
dieselclatterok Report post Posted November 30, 2009 On 11/25/2009 at 1:15 AM, Butch said: Here's a couple of gun racks that I made recently. Thanks for looking. Butch Nicely done. You sure know how to tame a wild piece of leather! How did you stiffen it up to support the weight? Quote Share this post Link to post Share on other sites
sodapop Report post Posted November 30, 2009 those are sharp indeed!!...when using the san carlos border...which i haven't done yet...how the heck do ya figure how much room is needed to start & end that border cleanly?? or when you come towards the end & gonna meet the start, do you just adjust more or less on the last few impressions?? Quote Share this post Link to post Share on other sites
Butch Report post Posted November 30, 2009 (edited) dieselclatterok, I use either 1/8" or 1/4" board. For the 1/8" I can just use large rivets, but for the 1/4" I have to get a bigger drill bit and recess out the back of the board a bit so that the rivet will fit. Then I just dye the edges of the wood to blend in with the leather. Thanks for looking, Butch On 11/30/2009 at 2:34 AM, dieselclatterok said: Nicely done. You sure know how to tame a wild piece of leather! How did you stiffen it up to support the weight? Edited November 30, 2009 by Butch Quote Share this post Link to post Share on other sites
David Report post Posted November 30, 2009 I'm confused, can we see one in use? Dave Quote Share this post Link to post Share on other sites
Butch Report post Posted November 30, 2009 (edited) Sodapop I should probably leave this to the experts and hopefully they'll chime in. My best shot at it is just from practicing it and trying to figure out the width of the border that I want and where the overlap will occur. Corners are the hardest part, but when I do I try to make it look like a spade in each corner. These don't have any square corners so they were a little easier to do. When I go from one side of the border to the other side I just leave a little bit of a gap from each tips and I think that's what works best for me. Hope that helps. Butch On 11/30/2009 at 3:42 AM, sodapop said: those are sharp indeed!!...when using the san carlos border...which i haven't done yet...how the heck do ya figure how much room is needed to start & end that border cleanly?? or when you come towards the end & gonna meet the start, do you just adjust more or less on the last few impressions?? Edited November 30, 2009 by Butch Quote Share this post Link to post Share on other sites
Butch Report post Posted November 30, 2009 Dave, I'm at work right now, but if someone hasn't already done it by the time I get home I'll post something tonight. Thanks, Butch On 11/30/2009 at 1:53 PM, David said: I'm confused, can we see one in use? Dave Quote Share this post Link to post Share on other sites
Butch Report post Posted December 1, 2009 (edited) Here's how I do the border. Currently I use the Craftool D444S I didn't notice that it has nicks in it until I took this picture. (Probably time to buy a good one) It is 1/4" wide I use a divider to create the area that I'm going to stamp and then cut it with a swivel knife. Using this stamp I make the inside area 3/8" wide Looking at the lines using the 3/8" wide area allows the top stamp center to align with the bottom stamps top and vice verse. Stamping the corner in the shape of a Spade: I leave a little bit of distance between the top and bottom stamp so that the border is close to the same size all the time. I've seen that if I don't put a little bit of distance the corners of the top and bottom almost cut into each other. Sodapop I can't really explain how to start and end other than what you mentioned. If I have corners I do them first and then move out from there and try to gauge where my next corner is so it flows correctly and you don't have two stamps at the top or two at the bottom. There's been times where I think it has all worked out perfect and then other times where I get very close and the ending or the border either gets really tight or really loose. It just takes a lot of practice and I'm still trying to figure that part out myself. After I'm all done I take a modeling tool and try to smooth out the rough areas. If anyone else has their own opinion on how they do it, please let us know. Hope this has been of some help. Butch Edited December 1, 2009 by Butch Quote Share this post Link to post Share on other sites
sodapop Report post Posted December 1, 2009 (edited) much appreciated takin the time to illustrate it butch!!...i'm sure it will help others as well with that border...its a really cool border to use...and i've been meaning to...but then i think about how i'm going to calculate the distance so it all fits clean and i go...ahhhhhh hell maybe next time lol but ya, makes perfect sense to do the corners/spades first...cuz if you screw those up...its gonna be very obvious...where on the others if the squiggle line is a little thicker or thinner than the next when your coming towards the end...not so noticable...then keep in mind to find a proper end point that possibly a strap may be stitched on top as well etc... Edited December 1, 2009 by sodapop Quote Share this post Link to post Share on other sites
PastorLance Report post Posted January 6, 2011 This is a really interesting way to use that tool. I bought one about a year ago and can not get the hearts to line up and look right. I think this might be my new way to use this tool as the other just does not work for me. Thanks for the post! Quote Share this post Link to post Share on other sites
